How to decide on which paint manufacturer?
I am a newbie and I am overwhelmed on tyring to decide on which paint manufacturer to focus on. I will specialize oin WW2 aircraft. The 1st model I purchaed was Tamiya and thus specified Tamiya paints. Subsequent purchases specified other brands and I am have difficulty cross referenceing to Tamiya.
I am looking for guidance on how to proceed with paint choices and purchases.
I don’t have a good answer since I’m also new to airbrushing, but I’ll tell you how I’m approaching it.
I am primarily interested in post WW2 jets. I’ve assembled a basic set of paints in the most used standard colors by FS number in Mission and Vallejo. I chose those because they seemed to cover the ones I’d be most likely to use. Both seem to generate an equal number of “love it” and “hate it” comments, so I assume it has a lot to do with the particular airbrush and environment. If one stands out, I’ll stick with it. If not, I’ll move on and try another brand.
MRP paints, which come in airbrush-only and brushable versions, are what I’m mostly using now. I build mostly post WWII jets myself and I find their FS colors to be really good for color accuracy. They shoot beautifully right out of the bottle and fully cure in less than an hour. They don’t require any thinner either. The only downside to them is that unless they specify matte or gloss on the bottle, all of their paints are generally semi-gloss. Not a big deal though, since most of us like to finish our military aircraft models with a final coat of flat clear. Many of their airbrush-only paints have a counterpart in the Aqua and Figure lines, and those are all brushable. They brush just as wonderfully as the airbrush-only paints airbrush.
Were I starting to collect model paints, I would go with MRP as well. I like both of the lines, acrylic lacquer and Aqua. I’ve used both and agree with Eaglecash on all counts.
Tamiya is great, but I’m in the don’t like to mix my own colors camp. I like Vallejo just fine too.
Back to the MRP, unlike Vallejo it dries fast and tough and lays down well everytime with no fuss. That said, I have enough Vallejo to open a small store and more Tamiya than I ever should have bought, so I won’t be changing over in earnest anytime soon. But my MRP collection growing.
Good luck and that’s sure a fair question. So many available brands.
Well I guess that makes 3 votes for MRP. A handful of colors just came in the mail today for a current project as a matter of fact. Like Greg I still have and use Tamiya paints due to my Tamiya inventory. Im basically a lazy slob so the no mixing thinner, just shoot and go seals the deal for me. As already stated the results are great too.
Still have a lot of Tamiya myself. I found that their Titanium Silver and Metallic Grey colors are great matches for the bare metal fixtures and cannon plugs in Russian jets. Building a Russian jet for the first time was the main reason I decided to try MRP paint. They have a great selection of paints that are perfect matches for the colors used on Russian aircraft. After trying it, I started picking up the US FS colors too to begin gradually phasing out my Model Master Enamel collection. Those enamels are awesome, but I’ve never been a fan of still being able to put indelible fingerprints in an otherwise perfect paintjob after more than a week of allowing it to dry. Its just too easy to burn into the stuff. With MRP, I deliberately tried to burn into it with fingerprints after 45 minutes to test the quick drying time…and I just couldn’t burn into it no matter how hard I tried. It also is much more durable than anything else I have used. Stands up to handling during detailing and assembly like no other paint.
Started ab’ing MM acrylic and Tamiya. Liked the ease of both. Shot a little of vallejo, no issues. Just got in a lot of Mr Color. Not that fond of the laquer thinner clean up, but like how it dries and holds up to handling so far.
Do you handbrush or airbrush,that will determine a lot.
Do you want to use enamels,acrylics,or lacquers
Which company makes the colors you need for a model
Availability of a certain line
Ease of use and learning curve
Get an App like Hobby Color Converter for cross refrencing colors
[dto:]
Excellent summary. You should consider all of these factors, though you may alter your choices at at any time.
Unless you are figure painting, I would go with Tamiya personally as they are good paints for both airbrushing and brush painting. They have been around for about 50 years now and are readily available. One bottle at my hobby shop is 1.88 USD whereas 1 bottle of mrp is $7 (then you have to buy a brushable bottle of the same color? No way. For general stuff I’ll stick to Tamiya. Mixing the colors they don’t have is not difficult and much info is available for mixing on the web.
Here is a F-100 I just finished with tamiya. Had to custom mix the tan and underside grey.
The standard Tamiya bottle is 10ml, MRP is 30ml…in the interest of a fair comparison. [;)]
MRP for me also when airbrushing. I really like being able to just put a few drops in my airbrush if I have something small to paint. Then run a little hardware store thinner through it and change colors if needed. No having to mix too much and through it away like you do if you mix a color with thinner. If I don’t use all the MRP that’s in the airbrush I can just dump it back in the bottle. As others have said drys quick which is also nice. The other night I was able to put a black base down, the color coat and a clear all within an hour easy and then decaled with no issues.
Yes, Thanks for that point… Very smart of Tamiya to let you buy smaller quantities. A beginner modeler can go pick up 10 colors to get started for less than $20 USD [H]
Also for airbrush ready paint, it’s more like u are buying 15ml of paint and 15 ml of thinner [;)]
I like your F100. I like F100’s since it was both from the era I grew up in and possibly the first jet model I ever built. And I agree Tamiya is a good choice if one doesn’t mind a little color mixing especially ( I’m pretty used to that myself).
I’m with you. I only use Tamiya exclusively. I needed Light and dark ghost grey for my current build. They only have those in spraycans, not acrylic. I did a quick search on google, found the mixing ratios, and made a bottle of each. Took no more than 5 minutes
I love the consistancy of Tamiya, everytime I buy a bottle, I know exactly what to expect.
Drop of retarder, and they brush paint perfectly.
Nice and easy.
Also a good point, but I’m expecting to airbrush with everything in the bottle. I still have Tamiya paints too, which I use for both airbrushing and hand brushing (with retarder as mentioned). The problem I sometimes run into with the Tamiya paints that I use a lot, is that every time I dump the leftover paint from my airbrush cup back into the bottle to try to not waste any of it…the paint in the bottle gets progressively thinner to the point where its still great for airbrushing, but won’t handbrush anymore because its too thin. I just like the predictability of something you don’t have to mess with, and you always know what you have left in the bottle, no matter how many times you dump leftover paint back in the bottle. The world is round, we all get there eventually. [H]
One of the biggest reasons I love the stuff. I’ve had to change my thinking about how much time a particular sequence of events takes to complete…allowing for proper drying time. What used to take days can now be done in an evening, even when its a short weekday evening. Gives me more time to have fun with modifying and tweaking things on the model when I’m not having to say “OK, I can’t touch anything for at least 3 days.”
You Tamiya fans,I still like and use them, and so far AK Real colors are just like Tamiya for me, I thin them with Tamiya Lacquer Thinner and it sprays the same with a tough finish,and they have a nice color range
I think I’ve tried them all.
Acrylics have some advantages, so you might stick with them.
I don’t use Tamiya except for basic colors as otherwise I need to mix too much.
I’m currently using AK as I phase out of Model Master enamels. The USN color set to my mind doesn’t match my colors perfectly, That may be because I am just used to the Testors.
Bill
So Calcio I hope that answers your question.
