How many projects at a time?
How many projects do you guys have going on at a time? I’m pretty much a fall-winter builder for starters so my time is a little limited, that being said I usually have two kits going on at the same time, when I’m waiting for one to set/dry I move to the other project. Anyone else do this?
Sort of. My build space limits me to about two.
Gary
1 for me. My OCD won’t let me go any further until my current project is complete.
Just one,unless it’s a especially big project.I did a 1/350 Akagi and a 1/16 Andy’s Tiger.Those were the only time that I stopped each to avoid burnout,and worked on something simpler,but those were the only times.
For me there is no limit. I have all sorts of projects half complete. My modelling time is very limited, sporadic and usually short lived. As well, I don’t really have a dedicated area to work. When I run into an issue with a kit or hit a point where I need a large chunk of time to complete something, it gets put aside.
This has resulted in a fairly large number of started kits kicking around with each one being revisited every once in a while to slowly move forward. It’s not the most efficient way to go, but at least I don’t have to find a place for a bunch of completed models. :joy:
Many different projects going and any given time.
Ahoy Demo. I usually have about four going at any one time and that is three too many.
Four or five or more at a time.
Idk I think with those of us that are limited on time it makes the most sense to have two or more so you can make the most of your bench time.
That’s the spirit, that seems to me anyways, to be the most time efficient way to go, although 5 is a bit much for me, two- 3 tops for this guy.
My rate of actual completion is about 1 in 5 :grin:
One is enough for me. This allows me to completely focus on doing the best possible build.
I’ve peaked at 3 projects at a time…
  • Main project
  • Side project while stuff is drying / setting
  • Side project to practise a specific new technique
Any technique-focussed side project will usually sideline the main project, but always with the express aim of improving major project outcome rather than being a distraction.
Anything more than that would probably be counterproductive and irresponsible on my part, since there’s only maybe two weeks of the year where my hobby is so intense that I need to work on three projects to cover setting/drying downtime
I guess it depends on what you mean by “going on”. Technically, I have 4 going right now but 2 of them have been sitting in a mostly complete state awaiting decals for several months now. I really need to motivate myself to finish them so I can get them off my bench. The other 2 I’m actually working on. I try to focus on one at a time but sometimes I’m at a break point and start my next project while waiting.
Like the others, I usually have 2-3 projects going on at one time. Paint or glue drying, waiting for supplies, or loss of interest/MOJO all can stall a project so for me it’s best to have “many irons in the fire”
I have more projects going at once than I would like. It gets overwhelming. At the moment I guess I have like two or three main projects going, but there’s a bunch of others that I haven’t worked on in a while.
Too many. Pretty much translates into a Shelf of Doom for me.
That’s my scene as well.
I currently have two big 1/48 B-24J Liberators on my bench. This was after doing 3 Grumman cats of WWII in 1/72 (Wildcat, Hellcat, Tigercat). The most I’ve ever had on my bench simultaneously was 5 1/48 P-40s (Monogram, Trumpeter, Academy, Hasegawa, and Eduard - not the recent Eduard but a repop of some other mfg years ago)
Well I’m pretty new ( after a 30 year pause) with only 2 complete builds and another one about half completed, and I’ve only done one at a time.
I have toyed with the idea of starting the second one while I wait for the next step, like putty or primer to dry. So far there has always been other components of the kit I can work on that keeps me focused on the one kit.
I’m not sure if starting a second kit would be healthy for me because I might just leave one behind. Also, there is only so much space on the bench.
