How I make my model bases (Pics!) EDIT: DO NOT USE THIS INFO-PROJECT FAILED
EDIT: RECENTLY I DISCOVERED THAT THE BASE DEPICTED IN THIS “HOW-TO” FELL APART. SPECIFICALLY, THE WALL JOINT COMPOUND I USED FOR THE PAVING CRACKED AND PEELED APART FROM THE WOODEN BASE AFTER HAVING SAT A MONTH IN MY DISPLAY CASE. THE INFO REGARDING MAKING THE BASE UP TO THE POINT OF PUTTING STAIN ON IS STILL GOOD, BUT I CAN’T RECOMMEND USING WALL JOINT COMPOUND FOR PAVING MATERIAL AT THIS TIME. PROCEED READING AT YOUR OWN RISK AND USE THIS INFO WITH A GRAIN OF SALT. SORRY ABOUT THE BAD INFO!!!–CHRIS
Although I enjoy posting up my completed builds, I’m not quite sure my skills are up to par to do a WIP post just yet. Making a nice display base for my kits has always been one of my favorite parts of the build, and I think it adds a lot to the finished product. I decided to post a how-to on those instead. Here’s how I do mine:
I get a 10’ X 12" board of nice oak from the local home improvement store. This one here is almost used up and has lasted me a good 11 bases so far, making the initial expenditure highly economical. Measure it out to fit your project, like so:
I use a circular saw I won in a raffle to make the cuts.
After two cuts, we have an 8"X8" roughed out base. This one here will be used for a little helicopter project that’s underway right now.
My wife got me this router for Christmas last year. Best tool in my inventory, by far. With a selection of carbide bits you can buy for them, a whole new world of decorative woodworking opens up. I highly recommend protective goggles when using a router as it kicks out a LOT of sawdust.
Here are the bits for it.
Here I’m 3/4 finished routing the decorative edge on the base. Unfortunately I don’t have a router table, so I have to do this by hand. You can see some of the burn marks in the grain where it got a little squirrely.
Here you can see the massive amount of sawdust generated by the router. I clean mine up and use it for firestarting when camping.
With routing complete, now we’re going to start sanding it for a nice smooth finish. I use 150 grit followed by 360, with a sanding block. Often my bases are so small that I can’t use a power sander, so I have to do it by hand. It’s tedious, but a good workout.
Making sure to get the edges…
Now it’s time for stain! I use a nice rich cherry color, with a cheapie foam brush you can get at the home improvement store.
Here it appears heavily applied, but I like mine to be as deep and rich as possible. Those of you who have worked with stain know that the length of time you leave it on, as well as the heaviness of the coat, dictates the final color.
Staining complete.
After your stain has been applied and left to sit for 10-15 minutes, it’s a good time to wipe 'er down with a soft cloth, or in this case, paper towels. This removes excess stain and allows it to cure faster.
And…voila! All you need to do now is wait patiently a day or two for the stain to cure. Usually I’ll start a base when I have a few remaining steps left in a model project, like decaling and weathering. This way the base is completely dry when you’re ready to put the model on it. Total time to make a base runs about 45 minutes, assuming it’s a simple one like this one.
After the stain is dry, you can carefully drill holes to accept mounting hardware for your model. I usually use clear acrylic rod set in a hole in the base to display my ships or aircraft. Alternatively, you can mask off the sides and build terrain on the top. On this project I will actually be building a helipad on top, so it will get the paving treatment. Stay tuned to this thread for some more pics as I progress on that. [B]
Chris
Well, for this base it’s time to start putting the paving on it. This one will be representing an airport helicopter landing area. I started by experimenting yesterday with a piece of scrap wood and some drywall joint compound.
It seemed to work out okay, so I masked off my base and laid a coat of the compound across the top of it. It seems a shame to hide all that nicely stained wood finish on top, but sometimes ya gotta break eggs to make an omelette, right?
I’ll wait overnight for this to cure, then I can sand 'er down and start detailing it. More pics to come!
I do not know anything about woodworking so this is a very informatif thread for me. Thanks for sharing!
Chris, you’re right about a router table being ideal, but a couple tips that apply to hand-held or table routing will help to reduce the burn marks. They come from “lingering” on one spot, so that heat from the cutter builds up. The best way to get rid of them is to remove smaller amounts of material, kind of sneaking up on the shape and then doing a final cleanup pass which removes the last whisker.
It also helps to moisten the wood before the cleanup cut so that the bit stays cooler, not sopping wet just damp. When you’re finished the last pass and the wood is dry, a fine grit foam sanding block with angled sides is handy to knock down any “fuzzies” - they are lot easier to use than sandpaper and last a long time. I get mine at a professional paint store, but a well stocked hardware store might also carry them.
Finally, it’s handy to have a foam mat under the wood to keep it from moving without clamps in the way. The pebbly foam carpet underlay, usually gray in color, works great. It’s sold by woodworking supply houses but is cheaper if you get it from a home center or carpet store. For modeling purposes a sq. yd. remnant would be more than enough.
Hope this helps - I’ve enjoyed learning from your modeling posts while lurking around the forums!
mike
learned something today.
Ron
Chris- thanks for posting your process. I know it’s something I’ll learn from as I haven’t yet tackled bases.
Good stuff Mike…I have the router but not the table so this info is definitely useful to me.
All I can say is: Thank you! This is very helpful indeed.
It’s interesting to see a new topic with info rather than a question, once in awhile
Also, I’ve been thinking of making a base for awhile. I’ll need the right model, though. However, I plan on just staining a base, which is already in a shape I desire. By the way, have you used those sample stain packs? How much area do you think that will cover?
I honestly haven’t seen those sample packs so it’d be tough for me to guess what they cover.
This is just my own process that I basically put together from my own garage. I’m sure everyone has different ways of doing it-heck, I think you can even get basic wood bases at Hobby Lobby and save yourself some woodworking. To me though, this is more satisfying and a bit more “custom” if you will.
MrMike, thanks so much for the tips. That will definitely help me refine my router skills! [Y][B]
Today I sanded down the joint compound and used a large flat-blade screwdriver with a straightedge to etch concrete shapes into it. Then I hit it with a first coat of MM Neutral Gray. Unfortunately I did get some chips and cracks, so during the weathering process I’ll have to get creative with those and make some weeds popping through or crumbled concrete to fill in or something. Not sure I’ll get to post up pics tonight, so hang in there and maybe tomorrow. Thanks for all the compliments, guys!
Hello again and thanks for the kind words. One thing I should have said is that the easiest way to sneak up on a router cut is to gradually lower the bit into the work. I’ve used the stain samplers from minwax and find they are adequate for a few square feet of material - much better than buying a pint or more for a small project!
best regards;
mike
Ok, gonna try and squeeze a few more pics in tonight. Here you can see the beginnings of paint as well as the concrete pad seams I etched in:
And here’s a shot of the base with the first coat of paint on it. I almost forgot that I would need to paint a big “H” on there somehow, so I went to work on that as well. I used Microsoft Word to type a big, block letter “H” and printed it out. Then I went to town with my trusty #11 and a straightedge to cut it out, leaving a nice temporary stencil.
Tomorrow hopefully I can spray on the “H” and get it ready for weathering. Not sure how I’m gonna do that as I’ve not weathered much before, but I’m thinking a fading spray of a lighter gray over the base coat and the “H”, and then a wash in the cracks using a light tan color to simulate a sandy, dirty type of pad. Of course, oil stains will figure prominently, but those I’ve done before. Thanks again for the nice comments and stay tuned! [B]
Had a quick moment after the kiddos went to sleep to spray my “H”. As you can tell in the pic, the overspray monster reared its ugly head. I had the stencil fairly weighed down, I thought, but the airbrush must’ve kicked up a bit of paper anyway. So much for that idea. Maybe next time I’ll mask it instead.
I think I’ll go ahead and weather the hell out of it rather than try to go back and fix it. I’ve got a busy next few days ahead of me with dinner plans and a day trip in the offing, so I’ll try to post an update later this week. Thanks again for watching!
Tuesday we took a quick trip down to Colorado Springs to drive the Pikes Peak Highway. My wife is a CPA and it was a celebration of the end of tax season for her:
We were forced to turn back 2/3 of the way up due to high winds and blizzard conditions. That’s my blue Jeep. Elevation here is 12,500 feet:
Anyway, on to modeling. Last night I spent some time on a wash. I hate washes. I’m not good at them and they never look good to me, at least, the ones I do. I tried one using MM Dark Earth to simulate some dirt in the cracks of the concrete paving. The joint compound I used for the base soaked up a lot of the wash, and using a Q-tip to wipe off the excess resulted in taking it ALL off. I wondered if I should have sealed the base before I tried the wash. Luckily it passes muster with my family and friends, so, no big loss:
After the wash, I made up some oil stains using Grimy Black and the leftover wash with a lot of Aircraft Interior Black added to it. This helped take attention away from the wash I did. There are two more oil stains that don’t show up in this pic. Trust me, it looks better in person than in the pic:
The Grimy Black came out really stark, but I’m hoping to tone it down as the weathering continues.
That’s all for now. I’m fighting some stomach illness issues right now so I’m about to go pop some Tylenol and go to bed. More hopefully in a day or two. Thanks for watching!
Ahhhh…so depressed. Nothing’s been going right the last few days, and modeling is included in that. The more I handled my base, the more I started having problems with the “concrete” cracking and chipping off. Finally I decided to just leave it where it’s at and wrap it up. I sprayed a coat of Valspar Clear Flat on it, and then removed the masking tape:
Here’s a shot of the clear gloss and clear flat sealers I’ve been using. I am REALLY impressed with that Rustoleum Clear Gloss. I used it on my AMT Starship Enterprise kit with great success. The Valspar has yet to be proven, but it appears ok on the helipad I just sprayed it on. We’ll see:
I’m going to call this model base build “DONE!” It didn’t turn out nearly as good as I thought it would. I’m kinda disappointed in the chipping I got, which I had to cover with paint because I just don’t have the patience to go back and fix it right. Plus I have two little kids that constantly take up my time. Overall though, when I get the helicopter and figures placed on it, I think it will look decent. Look for those pics in the “Helicopters” subforum soon! Thanks for all your comments and thanks for watching my build!
Chris
Chris- from the pics, your base looks excellent. It may not have been exactly what you’re looking for, but the cracking on the edges doesn’t detract from the realism to me. I say nice job!
In-Re: “I have the router but not the table”
My suggestion: BUILD ONE.
It’s no big deal to buy or build one (I have two, one for a Dremel, one that’s ancillary to my Shopsmith). Hit your library and paw through a few issues of Fine Woodworking and that ilk, you’ll find more than you ever wanted to know.
One “routed” base of which I am fond doesn’t involve a router at all. I simply make two evenly spaced, shallow passes (Shopsmith running as a table saw) on all four sides parallel to the plane of the base. (The trick is to make the same pass four times, then flip the workpiece and repeat – that way, irregularities are “erased” by the matching cuts.) Then angle the table 22.5 degrees and trim the board. Result: a visually interesting array, corrugated & set-back.
Here’s a link to the completed build, including helicopter:
/forums/t/137557.aspx
[B] Chris
EDIT: AFTER THE BASE WITH HELICOPTER MODELSAT IN MY DISPLAY CASE FOR A MONTH, THE “PAVING” WARPED, CRACKED, AND CAME LOOSE FROM THE BASE. DO NOT USE MY TECHNIQUE FOR THE PAVING UNTIL I IRON OUT WHAT HAPPENED. SORRY ABOUT THE BAD INFO!
