Hi I am wondering what you use to mount your starship on a base, especially if you have wiring from leds and such. I have used those rods for lamps, I like that they are threaded. I don’t like that they are threaded from top to bottom. I then used an old curtain rod to cover up the threads which worked ok. I guess what I am looking for is a hollow rod that is tapped on both ends to fasten to the model and the base. Is that what you all use or some other set up?
See, that is nice, looks good and does what it should do. Now, I should have said this before, but I am talkig about something large scale. I am working on a resin Star Destroyer that is 27 inches long, 18 inches wide and is a few pounds in weight. I need something pretty stout and probably at least two of them. I am thinking instead of a post to make a wood cradle type of stand thing. I don’t know, the post would be better as i think the wood cradle would be to bulky. I am trying to figure this out as I have a few large scale models that would benifit from what ever we could come up with.
What I have been doing is using a Twisted Cast acrylic square tube. I line it with a piece of polished Aluminum that is threaded on both ends. I epoxy the nut fot the subject inside it.Then the Blind nut is installed in the bottom of the base.
That way the weight is supported well and the wires run up inside the polished aluminum tube! I would’nt let it sit too off center or weight might result in a sagging Model!
A solution that works with ship odels is to use threaded rod inserted into sutable tubing.
The tubing can then support a sutiable washer to keep the tube from cutting in.
If your wiring is simple, just red/black +/- type stuff, you can bring the wires to one each of the threaded rods, and finish up the circuits under the base.
Now, if you need more wiring, you will likely want a larger tube. Threaded rod comes in quite small diameters and can be your friend.
It is possible to find brass unions which you could solder into suitable tubing to render a chased thread. But, those can be ellusive, too.
