Can someone enlighten me as to a method of painting a wood effect please? Im painting up the flooring in a 1:24 P51 Mustang and I want to simulate a plywood floor. When giving response in terms of paint to use please bear in mind the only paints avialable in my area are Tamiya, Humbrol and Revell, oh and I prefere if possible to use acrylic rather than enamal unless that is a problem.
Thanks
Antony
Heh Anthony,
SprueOne has a thread going right now regarding a Soviet Bridge layer and did a great job on the wooden planks.
Of course (in my humble opinion) the best way is to cut out the plastic and add wood!
Above is my 1/32 scale P-51 with wood floor boards added.
Thanks Suppresionfire. I have to admit that this is the very first time I’ve attempted to do anything that is not out of the box. I finally decided to pluck up the courage and have a go at scratch building a few items. So far Ive confined it to adding a few pipes to the engine. I gather from your photo that the flooring is flat? But on the one Im building its curved so I would obviously have to look at how to get it to retain its shape. The other item of course is that the original part has some mouldings on it which would have to be scratch built as well. Im not sure at this point if I would get anything like a good repro of it. (I guess you call that lack of confidence).
Nope my floor is curved as well. Kept the bulk of the plastic and just used really thin veneer wood strips securing down with a generous amount of CA glue.
I agree…the best way is to use real wood…I had the same problem with a Seiran I did a while back…no matter what I did the simulated looked just like that…simulated…so I went with the real thing. I used simple wood coffee stirers. Worked like a charm…trim as needed…sanded and simple wood glue. Then i used regular ol’wood stain on them…it brought out the small wood grain which of course visually enhanced the wood.
I was REAL happy with the outcome.
good luck
carlos
I made some “wood” decals. I shot pictures of one of my house’s plain oak doors. I then used Micro Mark decal sheets to print out the pics with my computer. I have used these for cockpit floor, prop blades, and a few other things.
Thanks guys. I think I shall have a go at using some thins strips of wood. The result is far more impressive.
