Hobbycraft 1/72 CH-46F Sea Knight, HMM-262 "ET-7" – a second chance for an abandoned kit
Hi all,
This one is a little different: it isn’t a fresh build, it’s a rescue. This old Hobbycraft 1/72 kit (HC2301, first released in 1989) reached me partly assembled and abandoned: aged glue, misaligned parts and an uneven, unfinished brush-painted coat. The panel lines, the glazing and many details were still good, though, so it deserved a second chance.
The recovery, step by step
Stripping: a bath in ethyl alcohol removed the old paint without harming the plastic.
Structure: joints reinforced with plastic strip, misalignments corrected with acrylic putty. Glazing: old paint removed from the canopy and windows, then polished back to clarity.
Extra detail: ventilation grilles and intakes added around the rear rotor area.
Configuration: rear ramp lowered and rotors folded, as for transport.
Painting
Airbrushed pre-shading over a dark base, trying to make the green “more than just green”. It’s a technique I didn’t know when I built this same kit years ago as a Canadian CH-113A Labrador, so it was nice to see the difference.
The subject
BuNo 156419 served with HMM-262 as ET-7 from 1978 until its retirement in March 2012.
And here it is next to my old Labrador, the first time I built this kit:
For me, finishing an abandoned model is a way of respecting the work someone else started, and of giving the kit the life it was meant to have.
Cheers from Córdoba, Argentina,
Ale
Fantastic rescue! Very well done.
Thanks a lot! Glad you enjoyed the rescue story.
Ale
Ahoy Alejandro. Many cheers to you and your helicopter. I am a big fan of model rescue and you’ve done a tremendous job on this one. Rescue work requires some high level modeling skills and you have them. Well done.
