Ok… On to the next huge build.
This is the latest release from HK and is an updated Lancaster and is really a 2-in-1 build.
First of all you have a complete original Lancaster kit with bombs etc to make the standard I/III bomber along with decals and build manual. You also have decals, extra sprue and modified fuselage interior to be able to build the grand slam version. If you go with the Grand Slam then you will have lots of parts out of this box to add to your spares OR to make extra display stuff.
The decals in this box will be sent to be made into paint masks. I see no reason to be messing around with huge decals when painting is the best option IMHO.
So… What is in this HUGE box…
Clear Sprues are in a protective “box”.
They also have some protective plastic sticky stuff on to prevent scratches
Likewise, the one piece wings also has cardboard stapled around its more delicate areas.
The fuselage halves have been modified for the grand slam and is referenced in the grand slam build manual and you have to cut out a section of the bottom of the fuselage sides. No Measuring needed though because…
… It has been marked for you. If you choose to do the standard Lancaster then this is left alone and is covered up by interior bulkheads and flooring. That cutout mark will never be seen!
The second interior cutout is part of the floor. Once again the cutout mark does not affect the floor and is hidden from view if not used.
All that makes the standard Lancaster Bomber. To make it into the Grandslam version then you need to use this sprue…
Decals…
Insignia and Stencils.
Standard Lancaster
Grand Slam including Bomb markings, although the Green ring has been missed (paint it yourself) and I think that the “red” colour is wrong. It is not the same as the standard red used for squadron codes and aircraft reg. It is more of a brown. I think Cartograf messed up. I also thought that the squadron codes on the tailplane was yellow edged in red. I need to do some reading and checking. These will all be painted (as much as possible!)
Right… That is all that is in that box. I have some Eduard AM stuff and metal barrels etc, so…
Let’s make a Lancaster!
