I just bought the revell Bismarck 1:350 model but i am fairly new to the modeling world (I know this might of have been a bit ambitious) and i was wondering what the best method was to paint the hull.
I have done some research into painting methodes and different sorts of paints, and it looks like the best options were spray painting and brush painting. But i dont really know what is the best course of action for this.
The spray painting looked far out the easiest and the most effective way, But i saw alot of people saying that an airbrush is a must and spray cans are not a good option. Now the problem is that i dont have the money for an air brush so… are the spray cans really that bad? Also which brand is the better option for these cans?
Now the brush painting is the alternative. My question here is what is the beter paint to use? The Acrylic or the Enamel ones? Again which is the better brand?
These questions might seem pretty easy to answer, but i have never painted a model before and i defenitly want to make it look amazing now that i spend so much money on it.
I would use rattlecans just for the big job of painting the hull,Tamiya has the basic red and grays for a ship.Just do it outside or have good ventlation,enamel can be nasty,and you have to consder overspray.As far as the smaller parts,you can hand brush.Vallejo Model Color brushes well. If your really getting into the hobby,try to save for a decent airbrush/compressor set up.You can get a nice setup for $300,if you can,get one.I realize this may not be possible,but its a good long term investment if your sticking with it.
Spray cans are fine. They add up though, I use red in a spray can for hull bottoms mostly because a smooth even finish is more important that any effects. But at $ 8 a can, one can per model, it does add up.
I also use rattle cans for large areas. It is a bit different than airbrushing or regular brushing. Any painting technique takes practice. Never try a new technique or a new paint first on a good model. Always try it first on scrap material, and when you are satisified with results, then move on to the models.
I prefer enamels, but I see the handwriting on the wall, and it is going to disappear from the market, so I am going to start practicing with acrylics getting ready for the day when I am forced to switch!
Using spray cans requires very careful control. Hardware store type spray paint cans result in thick paint applications if not used “sparingly”. These paints are designed for total coverage in one or two coats. Having a few runs on a repainted barbeque is acceptable; on a battleship hull it’s not.
It’s much more successful to use hobby specific spray cans. There aren’t too many choices; Testors and Tamiya and maybe a few that I don’t know of. Either of those are very good. It’s important to follow basic procedures; warm can, warm ambient temperature, clean surface.
Brush painting is also effective, and a good skill. Painting something as large as your Bismark would be a challenge, certainly not something to try without experience. If you look at the British hobby mags, those modelers brush paint a lot, in particular aircraft models.
Enamels brush well, acrylics don’t. But acrylics airbrush as well as enamels, and in a way with less fuss.
Try Tamiya AS-25 Dark Ghost Gray, AS-26 Light Ghost Gray, TS-33 Dull Red and TS-68 Deck Tan.
