Help with M36B1 references
I am ready to begin building an M36B1 (M36 turret on an M4A3 hull). I need help with Resources. My LHS that carried a good reference section, closed and I can no longer look at whats inside the cover. There are a few references out there for the M36 or tank destroyers but I can’t look through them to see if they will be helpful in my case. I need interior/exterior photos. Any unit or individual tank markings would be greately appricated. Color photos would be helpful if they are true to the WWII colors. There is a cd of an M36B1 manuel but I haven’t seen or herd about how helpful it would be. If you know of some good titles and publishers (ISBN) it would be a big help. I’m somewhat anal about my builds and I want to get them as correct as I reasonably can. Thanks, hope I can return the favor sometime, Greg.
Squadron does a tank destroyer in action that focuses on the M 10, M 18 and M 36 (inc the B1). I have it and it has pretty good pics, I’d recomend it for a start. There is also a walkaround (I would supposed it covers all 3 as well, but I don’t have it. There are a bunch of on-line sites as well you might try - prime portal being one. Also, the 701st TD and 899th TS have on-line historical sites, but I don’t recall which TDs they fielded.
Hope this helps
I built one of these a few months ago.Paint the inside of the turret Olive Drab.Surfaces below the turret ring are white.If you are building the 1/35 Italeri M36B1,I would ditch the vinyl tracks that come with the kit.They absolutely would not fit and I busted off an idler wheel trying to get them installed.I used the appropriate indy links.I think they were from AFV Club.
You may be able to find some new pictures of the M36B1, as oddly, the Iraqi’s ahad a few still in use. Just a reminder that the muzzle brake was applied after WWII.
http://www.thedonovan.com/archives/2006/08/the_rest_of_the_story_the_m36s_from_iraq.html
http://web.inter.nl.net/users/spoelstra/g104/iran.htm
Click to close image, click and drag to move. Use arrow keys for next and previous.
Supposedly these were originally vehicles given to Iran in the 1950’s.
I just re-furbished my old Testor’s/Italeri M36B1 and one opf the things that I added was AFV Club tracks, they fit perfectly.
Mike T.
/forums/748300/ShowPost.aspx
Check the above link.
/forums/725150/ShowPost.aspx
And this one.
I have not seen too many photos of these in service, though Concord’s “US Tank Destroyers in Action” has 2 or 3.
Are you building the Italeri kit or using parts from other kits?
