New modeler here, just started on my first kit, a 1/32 Revell A6M Zero.
Just finished putting a coat on the propeller and spinner, although I have questions about its consistency and look so far. I used enamel (wood) for the propeller, and acrylic (silver) for the spinner. The props do look a bit flaky and uneven. Pics of my current progress are linked below:
Before applying my paint, I applied a primer over the part, a Tamiya Liquid Surface Primer. It is lighter than the base color of the kit unboxed.
I did notice the primer to bit viscous, is this flakiness the result of having applied a really thick primer (in which case, just apply a thinner next time), or this a symptom of putting on too much paint for a first coat? I also washed the piece in water & soap before doing work on it.
When the flakes come off, do you see bare plastic where the flake was, or do you see primer? That is, is the primer flaking off too, or just the paint?
Sometimes acrylic ‘metallic’ paints have little flakes to make the finish look metallic. Not sure which silver Acryl you might be using, but maybe this is what you are seeing?
It’s very unusual for paint to come off of the primer. More likely the primer fails. Like Don said, you can easily tell by looking at the inside of the flake.
Says your “images are not publicly available”… But I think the replies above cover it so far… I had some primer that refused to adhere and “cracked” not to long ago, from a spray can…
To add to what you have recieved . I have found Tamiya Primer susceptible to " Finger Grease "
When you wash your parts , Make sure they are rinsed well and let them air dry .Then , With Gloves handle parts .
If you don’t have clean hands or use gloves then the dreaded " Finger Grease " will bite you .This is what it sounds like . Also any prop paint I do is as thin as I can get without being see-through . T.B.
