I am trying to think of some ways to scrath build headlights or tail lights for 1/35 armor models. Does anyone have some ideas or reference on how to do that? Any feedback would be appreciated.
Thanks and Happy New Year.
Most folks work with what the kit provides or go to the aftermarket for photo-etched accessories.
What are some brands of aftermarket details or P.E. that makes headlights. I am looking for German, Russian and British lights.
Thanks,
DM
Try cutting the noses off small scale bombs for headlights… For the German “Notek” light, I used two pieces of strip and overlapped them, then carved and sanded the round parts into shape. Add a stretched-sprue mount and yer done…
To replicate the reflector & lens on headlights bore out the headlight housing slightly. Paint the inside silver. Then mix up some 5 minute epoxy & put a drop of epoxy into the headlight housing. Allow the headlight to remain vertical while the epoxy hardens.
Another product to look for are MV lenses. These are available from most hobby railroad outlets. They are used to replicate the headlights & marker lights on railroad engines & cars.
Find yourself some Lite-Brite pegs…reds, clear and amber…you can make lights by cutting them up into specific shapes of mate them to other parts to make lights, beacons, spots any kind of light.
Another vote for the Lite-Brite pegs. One package will last you a lifetime of modeling. Translucent/clear Lego bricks work as well, provided the part you need to make is relatively small.
Kevin
That’s BLASPHAMY, Kevin! [:D]
Seriously… I’ve used clear plastic sequins or beads found in craft stores.
Helluv an idea, my daughter’s gonna be upset! I’ll go raid that stash before she gets home!!
Cutting up perfectly good Legos, you mean? [(-D] Well… I’ve still got my (very large) childhood Lego stash and let’s just say… I can afford to spare an occasional brick.
Kevin
Light bright pegs is a hell of an idea! I’m gonna have to try that out. I suppose you could even heat them up a bit and mold to shape fo rsuch things as nav lights on aircraft wingtips, maybe. I know I have seen a PE mold to make tear drop shaped nav lights. I’ll have to ask chuckw about that.
I’ve also used clear sprue to make landing lights, Heat it up a bit with my trusty zippo till it shape likes a mushroom/half circle. Let it cool down, which doesnt take long, then cut it off, bingo, you have a light. Trial and error to get the shape right though.
PM Sent, Kevin.
