Have you ever seen one of these? new pictures 6/18/11
Any comments/suggestions welcome.
[IMG]http://i889.photobucket.com/albums/ac96/apstevel/Ever%20seen%20one%20of%20these/S1100012.jpg[/IMG
interesting kitbash. what’s the story, Hal?
No.
[dto:]
Looks a lot like a ‘Loknar’ (sp?) class frigate from I think the FASA Trek wargame except for the sensor dish, weapons pod, or whatever it is over the warp nacelles.
The is is a kit bash of a starship modeler kit factory ship (perimeter action starship)… I bought one of the last ones, (it is on line on this sight) built it and though I could do better. I decided that a perimeter ship was much the same as a destroyer durring ww2. that ship was a picket destroyer, thus using radar to warn the fleet. since I have well over a dozen engines, i’ll be busy for quite a while. I took a etching of the kit factory ships hull and went wild from there. I had to remove the roto dome because it was crooked. I releveled it, then added 2 pieces of .060 sheet styrene. as it sits, I will paint it in overall grey. i’ll use stick on numbers and letters, then paint it overall a very dark charcole grey. Once the masked letters are removed, ill use stock decals then seal it. sll
how long is the model? you don’t paint it?
This ship is from the polar lights tos Enterprise kit. It is about 10 inches long. As for paint, I am still building and adjusting it’s final form. Paint is later. I have just about picked out the colors. If I use standad spray paint, i’ll buy it. if I get my air brush out of storage, i’ll mix my own.
SLL
from pictures seems smaller [:D]
good work, I’d like to see it painted
Whoops! Well a Loknar looks sorta like that.
Cool idea, I like the idea of the big sensor system. Looking forward to seeing more work on her. [Y]
well, today i was in the hospital all day doing tests. i am goind to die, but they cant say when. so i should post again sometime soon. as for the model, i had to remove the dome. ill put in an alignment pin and finish the ship without the dome. then i’ll put the dome over the pin and glue it in place over the pin and have done with itoms.
sorry for your situation, i’m without words
Thanks, i am ok today. next year who knows. as it stands my song will out live me, and it is still being written
wow, that was a tough one… finally finished this ship. it came out great, and up on a shelf. thanks for all the comments. sorry no pics, i have stopped doing that
ok, just to fill in the spaces. i bought one of the last perimeter action starship models from starship modeler kit factory. i built it as stated on the directions. that is also posted. then i decided that i didn’t like it. normally i would have delt with this little with several m-80s. but i was fresh out. so being a otherwise semi normal model builder, i decided that i could build better. to me a perimeter action ship is a scout, like the picket destroyers of ww2 fame. i took the upper primary hull, and 2 complete engines from my left overs. i scratched the secondary hull from .40 and .60 styrene sheets. i liked the hull shape, so it stayed. i decided that i needed somthing more. i remembered when i parked a navy gruman hawk eye aircraft. i liked the rotating radar dish, so i built one, again out of styrene sheets. i glued it toether, then found out that i missed the mounting surface by about 2 degrees. i sawed the radar off and rebuilt the dorsal. this time i aligned the dome mount with a spirit level. once that was in the bubble. I LET IT DRY. so far, this is the post you see. i let it sit for about a month. yesterdat i finished painting the hull. i will start decaling it soon
ok, well this one is just about finished. these should be the last pics. i only need to touch up the after portion of the engines. then sealer and shelf…
You must have an incredibly large Star Fleet. Neat stuff.
almost all of the 1000 scale federation stuff that has come out… i am starting to scratch build my own stuff now
ok, now i am confused. i was asked to paint it. i was asked to finish it. and as of yet i have seen no comments, and or anything. this is really … well i am not allowed to write what this is. maybe i should have included that gundam, at least there would be 10,000 comments by now… i give up
Comments comes with more pictures [Y] keep posting it
(what you do with 10.000 comments? you collect them? i prefere more kits to place on my room [:)] )
