I had so much fun seeing my Planet XP-40Q get to the finish that it just seemed right to go straight on to the next in line P-40 variant. It’s been pretty smooth sailing as I am just doing an out of the box build but with Eduard seat belts and this is such a nice kit. I’ve read that the aft cockpit insert can be a mis-fit, so I worked on that by removing some material from the mating surfaces of the fuselage in that area. I also assembled the tail sections to the forward fuselage parts so I could get a good fit there and that allowed application of glue from the inside. With the sides and top aligned there is a slight misalignment of some panel lines on the right fuselage half to clean up later, but they may be under the insignia decal.
I went through the instructions to find any other inserted parts but all I found were the lower gun panels, which fit very well and were glued from the inside. The instrument panel has a lot of relief, like the real thing with panels at different levels and some instruments recessed and other sticking out of the panel. I used the alternate decals without the black surrounding areas and had pretty good luck, probably because I used Mr. Mark Softer. Not much was happening with Microsol. Good enough for my 71 year old eyes. I wish I had leveled some of the switches on the mid level switch panel, I didn’t realize that Hasegawa had molded the switches on them.
I just looked it up- bomb racks. Starting with the P-40E-1, there were rack attachment points there for small bombs. Or a cover plate could be fitted there.
Not backwards so much as all over the place, as usual[proplr].
This is actually the second N I have done in the last 20 years or so, the other was the Hasegawa 1/72 kit that had all the international insignia. And I have a Special Hobby 1/32 P-36 and a Monogram 1/48 P-40B also in the display cases. Maybe I will do a P-40F or L before I burn out on P-40’s, who knows. Anything but go back to work on the Monogram/Lone Star B-26 I also have underway. I do need to do something on that one or two days a week, I think I’m suffering from PE fatigue on that one.
I have the neutral grey and some of the ANA 613 OD on the Hasegawa N, prop painting is in progress. I was surprised to find that the canopy parts which are in three sections are a little too long to fit, at least the way I have things put together. Of course I figured that out after gluing on the windscreen and aft section, whereupon I found that the funny shaped sliding section wouldn’t fit. I filed off some material from the back edge of that section and it then fit, but the intelligent way to deal with it would have been to test fit and remove the errant material from the back of the aft canopy section, or better yet take some material off of the back of the aft cockpit plug, which actually would improve its fit to the width of the fuselage.
I’ve also gotten some Accurate Miniatures P-51 wheels adapted to the Hasegawa struts and painted them. I understand the N used those wheels which are smaller than what is in the Hasegawa kit.
More paint. The next task is to do something to rescue this sweetie from the grip of boring OD and NG! Not even the Dark Green by itself will save the day.
Here’s where it’s at now. Most of the little parts to be added later have also been done up through paint. If you look closely at the horizontal stabilizer seams you will see I am still working them down after applying some thick paint with a fine brush to the join. I have also added a little aluminum powder in a few wear areas and dome some random addition of faded olive drab in areas that get the most sun. I am trying as hard as I can to let the paint cure up before I put on a gloss coat for decals, but I usually get a severe case of git’er done at this point which often does not yield the better result.
This one is in the display case, it has been a fun build. At the bottom, some photos next to the Monogram AVG P-40. I think the bird on the nose may be a parrot, I had a Red Lored Amazon that had somewhat similar coloring way back when, long story you don’t wanna know. You did not want to underestimate the power of that bird’s beak!
There’s a lot of photos, partly because I built it so I could display it closed cockpit with the Hasegawa hood and open using a Squadron hood, the vacform canopy section fits much better in the open position.
I used some wheels from an Accurate Miniatures P-51 kit on the P-40N as that was what they used instead of the wheels in the Hasegawa kit which are the usual larger standard P-40 wheels and tires. Quite a difference compared to the P-40B. The difference in the depth of the fuselage between the two is also very apparent.
