Can anyone in the uk recommend a GOOD compressor I went to Focus(Local DIY store) last week and bought one on “offer” for £79 6 litre tank moisture relief valve etc but the thing put out when switched on 99dba [:O][:O]
Thats a level 2 noise hazard area in the spare room!!!.
The dogs and cat went ape! Mind you so did Kath[:(!][:(!]
I have heared that there are problems with the Badger compressor with con rod and bearing wear that once they go thats it???
So at present I have airbrush but no compressor and there is now a long line at the paint shop[%-)][%-)][%-)] HELP
Thanks Nick
Nick, I’ve got a Werther 3.
Noise levels are relatively low, it has an internal 0.8L storage tank, it is a piston rather than a diaphragm type so no pulsing, and it cost me a £100.
I’ve had mine about 6 months and it’s been fine, apart from me dropping it off a table and mashing up the internal chassis. However having super glued it all back together again, it’s been fine ever since.
Try the link below:
www.maywoodgroup.co.uk/Compressors/SearchResult.aspx?categoryID=15
Karl
Thanks K arl I have had a look seems ok for the price
If you want somethjng a little meatier, try Screwfix Direct, who have a Wolf compressor, with a large tank, for under a 100.
Karl
or an iwata sprint jet.
Thankee peeps
