gluing polystyrene foam
can anyone tell me a good glue for polystyrene foam please ., I’ve tried white glue . after 4 hour’s that doesn’t seem to be working .I thought I would have a go at a sea diorama , but I need to glue these two bit’s of foam together first , any advice appreciated guy’s
If that’s the purple stuff they use for insulation, I’ve used Titebond II wood glue with great success. You can use T pins to hold the pieces together while the glue sets.
it’s the white gear they use for packaging ., blacksmith ., about 20 mm thick
3M, Elmers and Gorilla Glue all make foam specific glues. Frankly, I never bothered with any of them because the wood glue and pinning works well for me.
Elmers works a charm
Ditto that ! T.B.
it 's now over 10 hour’s an the white glue now seem’s to be holding ., I just didn’t give it enough time ., thank’s everyone
