Glue question
Hi guys
just getting back into armour kit building after being out of the hobby for a few years.
i have noticed that my supply of tenax has evaporated. Seeing the closest hobby shop to me is 45 minutes I was curious about MEK?
i see it at the hardware store and remeber a lot of guys use this stuff back in the day
does it do a good job or should I just make the trip to pick up hobby grade cement
thanks for any input
jeremy
I use weldon #3 for acrylic which can be found.at hardware stores. Very thin and exhibits the capillary action really well. Also use Tamiya thin which is cooler than weldon. Not sure about MEK.
MEK will work great, just smelly.
re MEK: Be sure to wear a vapor respirator when you’re using it. That stuff is dangerous to your health.
Can YOU present A-N-Y evidence that it has damaged somebody/anybody AT ALL?
Ok, there is a PDF showing that it MAY, repeat MAY — “Repeated exposure may cause skin dryness or cracking” ------.
There is nothing about it causing Cancer or any other serious illness, so why do foolish persons like you, continue to spread stupid and malicious misleading gossip about this product ?
It has NO greater impact on the body than petrol, so do you wish to mis-align petrol with the same stupid argument.
http://www.holmberg.se/upload/product/files/sds-methyl-ethyl-ketone-mek-eng-2014-08-19---733.pdf
I really expect you to at least read and acquaint yourself with FACTS, before offering such stupid and misleading statements on the web, remember that other vulnerable persons may read what you have said and consider it the absolute truth.
Now before you go firing of half cocked, please check out what YOUR FAVORITE liquid glue DOES contain, check out what the specific PDF say’s about that glue before answering.
Sounds like you have used it before, it works just as well as any other liquid glue used for polystyrene and at a fraction of the cost of the exorbitant prices model shops charge for other branded bottles of liquid glue. Virtually the same stuff anyway, so go for it, it works a treat.
A question for you please, if you have used this stuff years ago, do you have a third ear, or a third eye sprouting from your forehead, or, any foul vile cancerous growths showing anywhere on your body attributed to this MEK product ?
Inquiring minds need to know ----------- [;)]
Graham Green
Section 6.1 of the MSDS you posted clearly states to wear a respirator.
Nice rant though.
Mr Green:
This is supposed to be a community.
If you disagree with someone’s stated opinion, then by all means call them on it and state your own case in a civil manner. There is no need to fire back an out-of-left-field tirade as though it had been some sort of personal attack against you. Using the term ‘stupid’ in your rant no less than three times is just plain rude; suggesting that any statement will contribute to corrupting the poor gullible readership of the world-wide web is just bizarre.
All the materials handling data sheets clearly state dizziness and drowsiness as possible effects of MEK inhalation. More detailed studies–admittedly with animals, rather than us too-smart-to-know-better model-building types–suggest the possibilities of liver and kidney damage in high concentrations. Those facts alone might inspire any lucid individual to recommend the use of a respirator.
But you, of course, are free to breathe the stuff deep, if you feel that’s a better option.
Graham,
Beyond the fact that your post is pretty disrespectful to the person you are responding to, which we frown on on the FSM Forum, you are picking pretty lightly over the hazards associated with MEK. To quote the very SDS you link to:
SECTION 11: Toxicological information
11.1. Information on toxicological effects
Toxicological Information: Other toxicological data
Acute Toxicity (Oral LD50): mg/kg (oral rat) > 2000 - ≤ 5000
Acute Toxicity (Inhalation LC50): > 5000 ppm
Acute Toxicity (Dermal LD50): Rabbit mg/kg > 5000
Potential acute effects
Inhalation
In high concentrations, vapours are narcotic and may cause headache, fatigue, dizziness and nausea. Icke klassificerad som aspirationstoxisk (Not classified as asp. tox.)
Skin contact
Prolonged or frequent contact may cause redness, itching, eczema and skin cracking. Defats the skin.
Eye contact
Causes serious eye irritation.
Ingestion Ingestion of large amounts may cause unconsciousness. However, ingestion may cause nausea, headache, dizziness and intoxication. Ingestion may cause irritation of the gastrointestinal tract, vomiting and diarrhoea. May cause irritation to the mouth and throat.
Yes, it’s true that there are no known carcinogenic effects, but that is not what the poster said. It it clearly not something you want to be inhaling in large amounts. At the very least, it should be used in a well-ventilated area. If you are around it for extended periods or in large quantities, a respirator is a good idea.
Just to acquaint everyone with the facts.
I have new lungs, I wear a resporator or mask with any chemical I use in the hobby regardless of what the MSDS says. I’m protecting my new organs and would sugest the everyone protect what they have and not take them for granted.
Just sayin
And I’ll bet those cost a little bit more than the $ 10 or so savings on model glue. Not to mention the disruption it all caused in your life. I am so glad you are doing well.
As for this guy Green, IMO he’s best ignored. Yes, we all know that the Aussies have longer ones and their balls drag on the ground, point made. And we have a lot of members here from that continent who have better manners. It’s just the way this guy is, so don’t take anything he says seriously.
Thanks for your support, gentlemen. I only meant to make a helpful comment.
“I didn’t expect the Spanish Inquisition!” - Monty Python
Did some research on various “adhesives” a year or so ago. Most of what we are discussing here are not really adhesives, rather they are solvents that will melt styrenes.
I have sorted them by brand, contents and cost if purchased by the quart, or in enough 1 or 2 ounce bottles to make a quart as most hobby products are only available in those small sizes. Some hobby products as you can see have additives added to control the kick or speed. Some are just repackaged Methylene Chloride.
Tamiya liquid cement, orange bottle, acetone, butyl - acetate, $96.00
Tamiya extra thin cement, acetone, butyl - acetate, $104.28
Tamiya extra thin cement - quick setting, acetone, butyl - acetate, $91.01
In the Tamiya adhesives, the mix of butyl acetate and acetone varies by adhesive type, controlling the quickness or “hotness”.
Tenax 7-R, Methylene Chloride - 98 - 100%, $118.49 (Discontinued?)
Flex-file Plast-i-weld, Methylene Chloride - 98 - 100%, $98.24
Micro Mark Same Stuff, Methylene Chloride - 98 - 100%, $95.20
Plastruct Plastic Weld, (orange label), Methylene Chloride - 85%, MEK 15%,$76.32
Plastruct Bondene, (white label), Methylene Chloride - 55%, MEK 45%, $79.68
Ambroid Pro-weld, Methylene Chloride - 98-100%, (Discontinued?)
Testors liquid plastic cement #3502, Ethel acetate - 35 - 40%, MEK 35 - 40%, Propylene glycol methyl ether acetate - 25 - 30%, allyl isothiocyanate - .5%, $96.32
The following are products I have purchased from a local custom plastics fabrication shop. These are products they use. I can buy them by the pint or quart from them.
The first two make up the major ingredients in most styrene adhesives.
Methyl Ethyl Keytone, commonly referred to as MEK, also called 2-butanone, ethyl methyl keytone. $8.99 qt. can get at most bulding supply centers and paint stores.
Dichloromethane, also called Methylene Chloride. $33.98 qt. This is a very fast setting product with a high rate of capillary action.
Scigrip Weld-on #3,(very fast setting) Methylene Chloride - 80%, Trichlorethylene - 15%, Methyl methacrylate monomer - 5%, $25.47 qt
Scigrip Weld-on #4,(fast setting) Methylene Chloride - 60%, Trichlorethylene - 40%, Methyl methacrylate monomer - 1%, $25.47 qt
The Scigrip stuff I also use in my shop to fabricate sneeze guards for salad bars and such out of Plexiglass and polycarbonate sheet.
I have also downloaded the safety data sheets for all these products.
Hope you find this information useful.
EJ
“NOBODY expects the Spanish Inquisition! Our chief weapon is surprise…surprise and fear…fear and surprise… Our two weapons are fear and surprise…and ruthless efficiency… Our three weapons are fear, surprise, and ruthless efficiency…and an almost fanatical devotion to Aaron Skinner…”
I posted this info a while back, but not sure if it was even on Finescale. The prices may have changed some since I compiled the data. I did it just for my own knowledge after a discussion that took place at our model club. I found it rather enlightening. EJ
Welcome to MY world here!
Now somebody has to mentally prepare himself for a comfy chair… OH NO!
Graham, you’re a talented modeller, you build really pretty things, why do you have to be so annoying?
As for the glues - pure MEK or acetone for that matter, doesn’t really make a good styrene glue. It does’t melt the plastic too well and evaporates too fast to apply it to the parts and then join them together - you have to join the parts first, and then wick the solvent between them, not my favourite way.
It all changes when you add some butyl acetate - now this stuff changes things, now the solvent glue makes the styrene softer and the mix gets persisten enough to apply it even to larger surfaces and then comfortably join the parts, with time enough for corrections.
Now I didn’t have a chance to test the methyl chloride.
Thanks for reading and have a nice day
Paweł
I really think that a lot of ‘sanctimonious’ persons on here should do their own homework on what liquid glue they use, you’ll find a Material Safety Data Sheet on all the chemicals that ‘ejhammer’ has kindly explained what is in the make up of popular liquid glue’s.
Thank you to ‘ejhammer’ for that list, it has been saved for future reference, it’s nice to see that somebody has the ‘fortitude’ to post a sensible answer.
It appears that all these chemicals have one thing in common, that is the vapour can cause irritation, therefore, why aren’t all these other glues, put into the same basket as what MEK has been.
So why isn’t everybody on here, blasting away about the need to wear a “respirator”, when using any liquid glue ?
A simple face mask is about as usefull as ‘a pocket in a pair of underpants’, the face mask only filters out course dust particles, NOT a vapour.
Mr. Green
You have completely skipped over the reason your post raised objection, namely, your choice of harsh and insulting words in response to a legitimate question a member posted. The forums are intended for friendly and helpful conversations, resulting in a positive transfer of useful information.
As a member, I’ll appreciate your conducting yourself in a much more respectful and considerate manner, if you continue to participate in the forums. If you’re unable to do that, then I agree with GMorrison’s sentiment, you are best ignored.
Patrick206
I am an old fart and I continue to use Testors’ Liquid Cement in the red bottle. It smells, but so do I at certain times [:(]
Sometimes I use Tamyia extra thin liquid cement.
