Anybody have some good advise on how I can achieve the Splinter (NORM 72) Camo that Germany uses used on their jets? I have a Phantom that I want to paint as a German RF-4E varient but I’m not sure how to go about it. Do I mask and then re-mask the plane?
68GT Green painter’s masking tape! Fast on, fast off as the longer the tape is on the harder it is to remove. Never use the outside edge of the tape, sharp lines need to be cut to avoid contamination from the roll of tape kicking around your work area. Make sure the base coat is fully cured before applying mask. Yes light to dark is the prefered sequence.
