Ok…so what color should I paint this German helmet I want to place on the seat of this Sdkfz 250/1 I’m almost finished with? ‘German’ gray? Or will any gray do?
Thanks in advance!!
Glenn[:D]
p.s.- i use Tamiya acrylics
Thanks in advance!!
Glenn[:D]
While there is considerable variation, including the use of vehicle camouflage paint, this could be considered typical, although a bit faded;
I don’t know of any Tamiya color that matches, basically a dark greenish-gray.
i would think a weathered field grey look would be suitable
Glen; The basic helmet color is dark grey, but many where later painted in the field any shades from a dark grey through to dark green. They where given a white coat in snow or a buff color in the desert.
I have used Tamyia’s XF63 (German Grey) for a dark grey helmet and XF56 (Field Grey) for a dark green type.
Hope this helps.
Thank you for your responses! Helps alot!
Glenn
Anthracite grey. Testors MM II has it. Any grey that comes close to it will do.
Also some helmets were painted black.
