G4M Betty interior paint
Just starting the “Surrender” Betty build, and was looking over the paint cal outs this morning and Tamiya calls for the interior on their kit to be virtually all in gray, with the seat cushions in gunmetal.
Not being up on Japanese stuff from them, I would think that most of them would be an interior green of some sort. Will be installing the pre-colored Eduard office and belts to liven up things under the greenhouse somewhat.
If I do do the gray it would be Testors flat, and the green would be either Testor ZC (way to bright and light, but can kill somewhat with their reg. flat green) or MM 4862 panzer green from the acrylic line.
Exterior will be done in the navel green and camo gray/white MM4766, decaled with the meatballs, them over painted flat white with some blotchy show through as they appear to be very hurried paint jobs in the pics I have seen.
Thoughts are welcome, as are ideas.
The Model 34 that the NASM has (well a section of one anyway) is a pale interior green, looks similar to that used on the J2M and is probably a standard Mitsubishi interior color. They only give a Munsell number for the color, no FS reference. Hope this helps lead you in the right direction!
British interior green is very close to Mitsubishi interior green. May want to add a touch of khaki or buff to brown it just a little
Tamiya XF-71 Cockpit Green. I usually add a touch of XF-49 Khaki to it…
Lawdog, why do you recommend Tamiya XF-71?
Here’s a link to an old thread which has some interesting information about Betty interior colour.
cs.finescale.com/…/95921.aspx
Allen
Oh, man, I’ll be watching this thread. I happened across something on this aircraft on a FB post or something just the other day. Interesting story!
Chris
xf-71 is British interior green
Thank you, Tempest Johnny, I know. Still, I am curious about Lawdog’s reason for the recommendation.
So far, I like the fact that Chanter has done some research and located the rather good comments by Francois, whose identity I know. Francois is well versed in Japanese planes and has good critical thinking skills about them.
I am also impressed with goldhammer’s tentative color choice for some part of the fuselage interior. I’ll explain why a little later.
In the meantime, people might go looking for the comments of Chris Cowx on another web site. He said he visited one or more Betty wrecks and had some comments about aotake in the central fuselage.
For starters, Tamiya recommends this color for their cockpits in their instructions (at least my recent A6M5 did). For me, it’s reasonable to assume the shade was produced for this particular reason, zero cockpits. It’s further reasonable to think the Betty, a Mitsubishi, would be painted similiar. I usually brown this color it up a bit with some Khaki because I like to be different.
As Tempest said, British Grey-Green was similar to XF-71. For Spitfires, I add a touch of grey to XF-71.
To each their own. For my purposes these do the trick.
Joe
Okay, thank you, Lawdog. Nice work. (Did you know that about ¾ of all A6M5s were made by Nakajima?)
The Two Planes That Went to Ie Island
One was a G6M1-L, which was a conversion of the ill-conceived G6M heavy fighter. It has a hatch in the left rear fuselage that is not round. The ventral gun blister of the heavy fighter was removed to make the transport. I imagine that required some touch-up painting. Its passenger seating, if any, may be difficult to track down. It would be a royal pain in the bippie to move one or both lateral blisters forward on the kit to make a G6M1-L.
The other was a Model 11, which is not a Model 22, 24 or 34. So, we may or may not be able to extrapolate color information using the 22, 24 or 34.
Three Theories on Basic Interior Coloring of Betty
A. High-quality green finish for skin and formers of bombardier’s compartment, cockpit, tail gunner’s compartment, and possibly also the dorsal gunner’s area, but aotake central fuselage.
Mr. Chris Cowx reported that he saw aotake in the central fuselage of one or two Model 11s. He was looking at wrecks that had been outdoors a long time and he didn’t give much detail.
B. High-quality green finish for the entire fuselage interior.
An artist’s conception of a Model 11 interior appears in Osamu Tagaya’s book, Imperial Japanese Naval Aviator 1937-1945 by Osprey. No idea on what it is based.
There is also an artist’s conception in Maru Mechanic/Mechanic of World Aircraft showing a Model 22 with what seems to be a fully painted interior.
There is Robert Mikesh’s statement in Japanese Cockpit Interiors, Part 2, about the NASM Betty nose, “A consistent color [FS] 34151 is used throughout the interior.” This indicates a matt paint, which surprises me for the fuselage skin and formers, and suggests to me a somewhat oxidized finish. That booklet also has a 1944-vintage black and white photo of the waist gun area of a Model 22. It looks to have been matt, but the skin seems blotchy.
C. Some sort of gray for the fuselage interior, per Tamiya’s instructions.
We can only guess how Tamiya came to that conclusion. Large amounts of grays in a Japanese Navy plane of this period would be very unusual.
I have two color photos of the inside of the Admiral Yamamoto wreck. They were published in the pamphlet “Papua New Guinea Battlefields” in 1981.
The first one was probably taken with a flash. It shows the inside of the wrecked central fuselage, including the left side entry hatch. The view is forward from the tail gunner’s compartment bulkhead. The condition of the interior paint is terrible; this wreck had been outdoors for over 20 years before it was photographed.
The hatch interior is a speckled mess. Maybe 50% is bare metal, quite dull and corroding. On maybe 35% there is what I take to be very deteriorated paint or mold or algae which is a light khaki green along the lines of FS _4552, but a little browner. On the remainder are virtually black areas. They may be alive, or they may be paint.
The formers in this photo are about 75% bare metal, and 25% in a variety of greens, ranging from something like FS _4441 all the way to approximately _4092.
The skin is terribly blotchy and is missing maybe 60% of its paint. However, there are spots of 1 to 8 inches long that are very dark, almost black. They seem black-green, but some spots may be a super-dark blue.
The corrugated flooring also has some of the same very dark colors, but also some faint traces of translucent greens and turquoises.
The second photo shows a bit of canopy frame. The inner surface has a huge variety of greens, the darkest of which is roughly between FS_4108 and _4128. (Canopy frames were often brush painted with aotake and nothing more. They do not necessarily match the fuselage skin in the cockpit or the instrument panel.)
In other words, the photos show a patchy mess of colors consistent with aotake. I think we need to get shed of the idea that aotake was always translucent or always some sort of electrifying aqua color.
The Modeling Issues
It is tempting to think that the interior of a Japanese Navy bomber would be pretty much all one color and all to the same quality standard, but when we consider that some parts, such as radios, guns, and a lot of other things were provided by subcontractors, and that in many cases the subcontractors painted those things in other colors, we can see why a seat may not be the same color as the floor and why the little toilet in Betty may not be the same color as her instrument panel. In WWII, Japan relied on thousands of small workshops (under 20 employees) to turn out all kinds of things for airplanes. It goes without saying that they didn’t use identical paints.
That brings us to “aviation archaeology”, “relicology”, “wreckology” or whatever you want to call it. How much do you want to extrapolate about the many colors inside an airplane from a scrap of skin that a serviceman cut off a plane 70 years ago? Or from the photos in my travel booklet?
Although greens like RAF cockpit greens tend to be associated more with Nakajima products for the navy than Mitsubishi’s, I won’t say that they could never be found in a Betty. I think my little travel pamphlet shows that they did turn up in the central fuselage in small quantity on little patches of formers. Some of what I see in the Yamamoto wreck could easily lead someone to think of RAF cockpit greens. Quite possibly the instrument panel, too. Maybe a seat in the nose. Maybe a map case. Much of the skin? Not from what I have read and seen.
Goldhammer, I like that you look beyond model airplane paints to find a color you think is pretty close. In fact, if you were to add a little black and a little warm dark brown to that Model Master 4862 Panzer Green, you’d get pretty close to Gunze Mr. Color 126, “Cockpit Color Mitsubishi Group”, which I’d be tempted to use for much of the interior of a new Model 11 Betty, except in the central fuselage. What you’re modeling is not a new plane, so I think the 4862 shows excellent instincts about how to start the bombardier’s compartment, cockpit and tail gunner’s compartment, just so long as you don’t go too monotone in those compartments.
If you make an aotake central fuselage, it might be tricky to render in scale. Personally, I would not use layers of translucent paints over silver or spray metallics. This compartment was not at all flashy, if I am reading these color photos correctly.
Thanks for all the great research info Spruesome! On the subject of aotake; I tried to replicate that on this “what -if build”, the Kyushu J7W3 Shinden. I sprayed several light coats of ModelMaster Teal acrylic over a base coat of unpolished aluminum. It turned out like this:
HAY GOLDHAMMER I’VE GOT THAT ONE IN MY STASH TAMYIA TYPE 11 WHICH ONE ARE YOU DOING? BE WATCHING THIS ONE. ACESES5 ON BENCH ITALERI TPPHOON MK1B LATE
Texgunner, I think you’ve got a pretty good start there.
The aotake coatings were not just “protective coatings” as we have been telling ourselves for years. FOR SHEET METAL they could also be used as a layout fluid, along the lines of DyKem layout fluid. (There was a big difference in the formulation of aotakes from DyKem, obviously.)
After the aotake has dried on a big sheet of aluminum, a sheet metal worker comes along with a template and an awl and scratches outlines in the aotake to show another sheet metal worker where to cut, and another worker where to drill holes for rivets, etc. Later, after the fabrication work, the sheet is riveted to formers, wing ribs, etc. The formers, wing ribs, etc. could easily be in an aotake of a completely different color.
Please have a look at Mr. Nakamura’s photo here. Scroll down about two-fifths of the way to a glass display case and see item number 7. The numerous colors on the skin are not even close to the colors of the framing:
a6m232.server-shared.com/CCP1.html
The caption for item number 7 says this is a piece of fuel tank from the left wing of a Mitsubishi plane that has the manufacturing number 3938.
As you can see from Mr. Nakamura’s photo, the sheet metal was not painted in the same material as the framework was on this piece. So, for your next model, you might try dry-brushing a little light metallic gray on the framework, followed by dry-brushing with some dark greens giving an incomplete coverage on the framework, if you want something like this piece of fuel tank. You could also try a wash of a darker turquoise (turquoise being greener than aqua) for the sheet metal. Of course, Kyushu was not Mitsubishi and may have done things differently, but that would be the general idea.
Aces- kit#61049-4800. OOB with an office set of PE and probably SAC landing gear. Have only seen about 3 pics of them on the ground and they were not real closeups. So- one of the two, take your pick, and drop your money on her.
Ended up with straight panzer green for the interior with some alum. and steel dry brushing. The PE IP is a little lighter green, bu I’m OK with it. Won’t see alot of it at any rate. Will do the exterior in the army/navy green upper and gray/white lower and then a flat white somewhat blotchy overpaint, as they would have been done in a hurry. Will be disarmed, and look the part, even if not a perfect replica. (Good enough for the guy building her)
I’m planning on start a betty soon as well. I recently got the ijn aircraft colours from ak interactive, in addition to standard exterior colours it comes with mitsubishi int green, and nakajima int green. I’m planning on using the mitsubishi int green on my betty
