My hat’s off to you John! That’s great work for your first AB paint job. Very nice beginning dude! Keep the pics comin’.
Gary
Gary
Hey guys, I’m very embarrassed, [:$] I think my use of words was misunderstood. I meant to say that I have never done a camo using mottling (WWII German), mostly straight edge and masked type of air brushing, SEA and US navy stuff when I was doing it in the mid 80’s. I have however not picked up a air brush for about twenty three years since shortly after I got married.(until last year that is) so I am a little rusty,
And I had never done any type of weathering until last year when after I went to my first show here in Minnesota. And now a shameless plug for our web site. I probably wouldn’t have either if I didn’t get on this web site. Between 1990 and 2006 I was into scratch built R/C jets, fiberglass molds and everything. I did however build models from about 1966 to 1989, plastic, rockets etc etc. It’s what happens when you live 3 blocks from the best hobby store in the state (not kidding!) most of my lawn mowing money went there!
So when do I get strung up for my 40 lashes with a solveset laced brush![:XX]
John
No worries there John. I guess that is what I get for assuming. This in no way though lets you off the hook for receiving major cudos for pulling off an excellent Luftwaffe mottling for the first time. Nice!
I realised what you meant, and kudos from me were based on same.
I’m still apprehensive to try freehand with the AB (but going to if my 190 arrives before this GB is over, so my hat remains tipped to you, John. No need to be embarrassed, I think.
Thanks Joe and Greg,
I wouldn’t be to apprehensive, I practice on a piece of card board the way I want to paint it before i actually spray the plane. I do have one concern the spray pattern has rather large spots of paint, is this because I’m not thinning it enough or to low air pressure? Not sure how to reduce the size of the spots of paint, I do have the finest needle in my paasche AB.
John
If I remember correctly I upped the pressure to about 30psi and adjusted the needle to where there was barely any paint coming out and just kept the AB moving. That was done with a medium needle/tip though.
I’ve got one of those old badger type compressors with no pressure adjustment or tank. I do have a water trap/pressure dial that I was going to add to it, will the water trap act like a small air tank?
Not much of one if any. You can get an air trap with a pressure regulator on it though and that’ll work. Thats what I have.
When I get home tonight I’ll have to look at it and make sure its not a pressure regulator.
Don’t mean to interrupt the interesting compressor discussion, but thought someone might get a kick out of this.
My 1/48th Hasegawa fw-190 arrived. Just opened the box. Bear in mind my point of scale reference is the 1/48th TBM Avenger I am finishing up. That and a 1/32nd F-15 Eagle, my last and only surviving model build.
I panicked, thought there was a mistake, Hasegawa had packaged a 1/72nd kit in the 1/48th packaging. I actually checked the physical specs of both aircraft online. I had no idea what a monster the TBM was. Or that the 190 is so small. Or whatever.
I have a question; the manual references some “RLM” colors. I’ve seen RLM colors tossed about here, have no idea what they mean? Also, my Academy kit called out colors from several mfgs. The Hasegawa just has the colors. Whatever RLM means, I assume they are not paint mfg specific?
TIA.
Edit: Oops, forgot about Google. Figured out RLM. D’oh! Every one is available from Gunze in their Aqueous line, which I cannot get over here. Grrrr.
Off to check if Tamiya has any RLM colors…
Tamiya will not list (usually) RLM. Some kits recommend “blending” colors by percentage to achieve the desired color. RLM (I would also have to look up even though I’ve read it a thousand times) were the colors approved by the Reich war ministery. The colors I use mainly are the Model Master acrylics which are already blended to standards,(also available in enamels) I think a lot of Tamiya kits of coarse recommend their own close match paints and are very good paints. Several other kit mfgs will send along a chart showing which paint mfg blends (Mr color, Humbolt, etc…) will work best. It can be fun experimenting, but just remember to mix enough to do your project as I’m sure you know you can rarely ever blend again and get the exact color.
LOL, yes, after doing a 1/32 and an Avenger to boot, I’m sure the 48 did look a tad small! LOL I generally like the 1/32 but have done a few 48s for people recently, and find I have to re-train myself all over again due to the size diff.
Hope this helps…Take care
Doug
Hey, thanks Doug! Didn’t realise Model Master had RLM colors, I just bit the bullet and ordered some Vallejo Model Air RLM colors from Squadron.
Good advice re mixing enough. I did my first ever custom mix for the Avenger, due to mistakes mixing, thought I mixed up way too much. Ended up almost running out of one, proves how right you are!
Honestly, I didn’t realise how small normal 1/48th WWII fighters are. Amazing how my sense of scale got lost over the gone years. And here I was thinking 1/32nd would be far too big. Yikes.
And regarding the three crew TBM, oddly, during my entire build, even though I saw the interior right in front of me, the obvious large size of the aircraft never really occurred to me. Odd.
I now have a rather burning desire to see a refurb in person somewhere.
RLM stands for Reichsluftfahrtministerium. That is German for “Reich” aviation ministery. It was a ministery for everything regarding aviation in the 3rd Reich (civil and military).
“RLM-colors” are basically numbered standard-colors used to paint aircraft. RLM-66 for example, is standard-color nr. 66, which is a particular shade of dark gray.
And yes, the Avenger was a monster compared to some other planes. Don’t forget the fact that it had a 3 man crew compared to the single pilot the 190s had…
I hope I could help you out!
Cheers, Clemens
Clemens, thanks buddy! That all makes sense now.
A bit embarrassed, I went brain dead and forgot about googling my question. But it’s more fun annoying my new friends here anyway. ![]()
Not every 1/48 fighter is small. The Thunderbolts I am working on ATM are at least 4 cm longer than a 190A. And 1/32 models of those flying milk jugs are huge buggers… Th 190 is just one of the smaller fighters of WW2…
No worries, mate. You can ask me any question you want about German names and stuff. I am also gladly offering my service regarding translations of German stuff.
Wait till you build a 109! Those things were tiny!!
Thanks for the further info Clemens and Eric.
Interesting to know that the 190 were one of the smaller fighters, and now Eric I’ll have to build a 109 just to see! I can see the fun of having a 1/48th fleet from the standpoint of seeing the relative sizes.
Clemens, Park the 190, or the 109 next to our next build the Do335! All single seat fighters but wow what a diff! Many years ago I saw a JU88 in a muesum… What a monster that is!
Eric: I have a 1/48th 109 in my stash (E-3 by Eduard) and it is indeed tiny… I don’t think I would fit into one of those little machines… (I’m 1.83m)
Doug: That would make a nice picture! I’m so going to do that!
Greg: Yup, that would be a nice project. Building every single-seat fighter of WW2 and lining them up sorted by size would be really interesting. I’m pretty sure that the Spit and the 109 would be on the “tiny” end of the row and the Thunderbolt and 335 on the “frickin huge” side… I’m still impressed by the size of the Jug (its engine is as tall as an average human…) and the 335 is even slightly larger…
