Okay guys,
Not to get TOO technical, but there is a website in Japan that offers paper models and the guy has specs on EVERY variant. It’s in Japanese (obviously) but babelfish is a great thing:
Observe:
Fw190A-0 Preproduction machine which had 1 of 2 types of main wing style and wingspan.
Fw190A-1 Early production type. BMW901C-1 engine (1,660hp) loading. 7.92mm machine gun × 4
Fw190A-2 BMW801C-2 engine loading. 20mm machine gun × 2, 7.92mm machine gun × 2
Fw190A-3 BMW801Dg engine (1,800hp) loading. 20mm machine gun × 4, 7.92mm machine gun × 2
Fw190A-3/U1 Close-in support version. Adding the bomb load capacity to 500kg to A-3. Also a U3 type exists.
Fw190A-3/U4 A-3 based spyplane type. Decreases the number of 20mm machine guns to 2 and adds a camera.
Fw190A-4 BMW801D-2 engine (2,100hp with water methanol injection) output enhanced.
Fw190A-4 Trop The tropical specification type which installs the anti sand filter onto the engine of the A-4. Bomb rack added.
Fw190A-4/R6 Removes the water methanol fuel injection equipment allowing the addition of under-wing antitank rockets.
Fw190A-4/U8 Decreases the number of 20mm machine guns to 2 increasing the fuel tank capacity
Fw190A-5 Engine position moved 15cm forward, improving fuselage balance & C/G
Fw190A-5/U2 The night fighter type of A-5. Low-temp output muffler equipment
Fw190A-5/U3 similar to the A-5/U2 fuselage, with the addition of bomb rack units under the body and wings.
Fw190A-5/U4 The spyplane type of A-5 with 2 cameras
Fw190A-5/U6 The fighter bomber type of A-5 with the night-fighter equipment removed
Fw190A-5/U8 Long distance fighter bomber type of A-5. Increased main fuel tank capacity.
Fw190A-5/U11 Close-in support type of A-5. Under-wing 30mm machine guns
Fw190A-5/U12 Armament enhanced version of A-5. Under-wing 20mm machine gun pods
Fw190A-5/U14 Anti-warship attack type of A-5. On-board torpedoes
Fw190A-5/U16 A-5 variant. 30mm machine gun × 2, 20mm machine gun × 2, 7.92mm machine gun × 2
Fw190A-6: The first model which adopts the lightweight main wing of the new design. 20mm machine gun × 4, 7.92mm machine gun × 2
Fw190A-6/R1 A-6 variant with six 20mm machine guns
Fw190A-6/R2: Replaced one 20mm machine gun found in the A-6 to a 30mm machine gun
Fw190A-6/R3 Replaced both 20mm machine guns found in the A-6 to 30mm machine guns under the wings
Fw190A-6/R6 Addition of an antitank rocket pod
Fw190A-7 It is similar to A-6, but replaces the 7.92mm machine gun with a 13mm machine gun
Fw190A-8 It is similar to A-6, but the model has an increased main fuel tank capacity.
Fw190A-8/R7 A-8 variant. With an armored cockpit
Fw190A-8/R11 All-weather type of A-8. Addition of cockpit heating equipment
Fw190A-8/U1 A-8 variant. Conversion to a 2-seat training aircraft
Fw190A-8/U3 Addition of remote control flight bomb equipment
The site has this info for nearly ALL WWII fighters. The address is http://trotskiy.moo.jp/
Enjoy,
