Future uses
I have heard alot about using future as a buffer between coats of paint and as a sealer or protectant. How much do you use and how do you apply it? Are there any other uses for Future? someone please help. I am just coming back to the hobby.
A lot of the folks have written some good stuff about uses for future. Go to the bar above. Next to FAQ is a search function. Put in “Future” and you’ll get a bunch of posts on the subject. Everything from attaching clear plastic parts to creating a flat finish. It will be easier than everyone retyping all those posts [:)] Welcome back to the hobby!
Dave
I agree with dave. You can also try going to rec.models.scale and take a look at their FAQ. There is an extensive section on Future that will likely answer most of your questions.
Future is probably my most use product next to CA glue.
M.
thanks for the help!!!
use it undiluted as you say. you can use it as a satin/gloss coat too.
School holiday?
what does that response have to do with future?
Thought you had some spare time…
I use Future for:
Glossing up the surface for decaling and as a barrier for solvent type wasshes
Stubburn decals can be applied over wet Future then coated over with it to seal the decal in place
Brushing multiple coats of Future from the center of the decal out gets rid of thick film edge know as a ‘Step’
Canopies dipped in Future look clearer and hides small scratches
Can be used to attach clear and small pe parts
Can be mixed with certain flat acrylic paints to get desired sheen
A drop on instrument faces will look like glass
Can be used as a pigment fixer for modeling wet mud
