This was my first attempt at dipping a canopy in Future, and I touched it too early now it’s marred. I want to remove the Future and then re-dip the part. What do I need to use to strip the Floor Polish but not harm the plastic canopy?
Peace-
Boris
Peace-
Boris
Windex (ammonia). This is also useful if/when the framing paint job gets screwed up and you need to start over.
Thanks! A lot!!
Peace-
Boris
Sure. After you dip the thing, holding it with tweezers by a corner of the frame- touch the bottom corner to a piece of paper towel a few times to “wick” off the drop of Future thats formed there. Then set it on a clean piece of paper.
Just to add my [2cnts], I like to tear the paper towel and use the torn edge for wicking, it wicks better.
I’m with GMorrison 100%, everything he said. Same as I’d do.
Thanks to you both!
Peace-
Boris
I rather polish the inside and outside of the canopy with Novus.
This doesn’t address the question at all - but thanks, I guess.
Peace-
Boris
Boris, as you probably know: Future/ Pledge is an acrylic floor finish product, something janitors use.
When it builds up on a floor, the maintenace folks splash something on it like Windex which is an ammonia based product, hard mop it all off and start over.
As an aside; any time you use Pledge over paint, and then weather wash over that, and f uck up: ammonia will erase all sins.
Bill
GM gave you the best method to remove Future. My post was simply a suggestion on a different way to improve clarity in canopies.
Better man than me. I curl up in a fetal position and cry.
But seriously, the Novus product 1-2-3 will almost always restore an accurate finish to a scratched canopy over the length of a baseball game on the screen.
Bill
GM I use either an old cotton t shirt and or Qtips and only use Novus#2 to polish out for example the dreaded seam line along the center of the F14 canopy . [:@]
I sand it off using several grit sticks then hit it with the Novus and after 30 ish minutes it’s crystal clear.
Mustang Joe introduced me to the Novus system some years back.
Wonderful stuff.
