Future floor wax help
how would i apply it to a autobody after i airbrush the body and all i want to give it a high shine how would i apply it to the body???
Hi thermoshok,
Future is great for many things, but when I want a deep glossy finish on my cars, you just can’t beat hand polishing. I use Novus polish with and finish with “the final detail” model car wax. It dosen’t matter what paint you use. Micro Mark (right here in NJ) offers both of these. Hope this helps.
dphaze
I air brush Future on my models. I usually thin the Future about 50% with Windex window cleaner and spray the future on in light even coats. Enough to cover but not enough to where it runs. I usually let it dry about one hour between coats and usually apply two to three coats. I use the Windex to clean up the air brush followed by lacquer thinner. After the Future has dried 48 hours you can sand and polish it if necessary. Hope this helps.
Mckay[C):-)]
thanks guys that helped alot and cleared up alotta confusion thank you
In case you didn’t know, future is also great for other things. I dip my windows in it and it makes it seem alittle thinner, more realistic to the size of the model.
Make sure you use the Windex with ammonia, otherwise it doesn’t work.
