Hey guys. I have a new problem regarding my airbrush that I find both interesting and frustrating.
First off, it’s an Aztek A480 airbrush. I am using an Aztek AC200 compressor.
Last night was the second time I’ve tried to spray Model Masters Acryl gray primer. I thinned the primer appx. 3 parts primer to 1 part Testors Acryl thinner. I put the mixture in a gravity feed cup and set the compressor to 16psi. I am using the black, higher flow nozzle that should be for acrylic paint. I rolled the paint flow roller all the way to the left for a closed position. I held down the trigger (without moving it back) and adjusted the paint flow until a little bit of paint started to spray out of the nozzle.
At this point, everything seemed great. I sprayed the primer for about 1 minute, and then the pain flow stopped. So, I tried to set up the process again. I rolled the paint flow to the off position, and slowly opening it again until paint comes out. This time, nothing comes out. The only way I can get it to start spraying paint again is to pull back on the trigger and put it into double action. The paint spray works for a while at that setting too, and then flow stops again. While in double action, I get a lot of bubbles in the feed cup, which I thought was an indication of a leak. I don’t know why it would not do that in single action mode though.
Anyway, so all of this leads me to believe somehow the primer is clogging up the nozzle. So, I cleaned the airbrush, thinned the primer more, and tried again with the same result. This time however, the primer was obviously too thin and was running all over the place when sprayed. This same thing happened the first time I ever used the airbrush, when it was brand new.
So, is it something I’m missing? Thinning ratio incorrect? Wrong nozzle? Bad form on my part? Should I not try to airbrush that primer? I haven’t tried normal paint yet because I’m getting frustrated just laying down the primer. When the airbrush sprays correctly, it’s a lot of fun. That only lasts about a minute though.
