FRAGEZEICHEN PATTON 48 (BergePatton M48)
Photo album for this build, at least until I get this properly sorted:
http://imgur.com/a/uazR6
With some hub-bub over the “BergePanzer Tiger” with a couple new kits and the descriptive title of these kits, I decided to bash out my own version while away from the bench visiting my nephew for a week.
Three of the four kits that I know of in 1/35 plastic:
CMK box art sprueone
Italeri box art sprueone
Rye Field box art sprueone
The old 1981 Tamiya M48A3. Everything is from the box except the flint striker from a disposable lighter.
Tamiya box art sprueone
M48 upper hull sprueone
M48 upper hull fenders cut off sprueone
A fenderless tank is something I always wanted to do.
crank frame template sprueone
crank frame parts cut sprueone
parts cut sprueone
turret parts layout sprueone
The winch frame made from the fenders.
scratch built pulley wheels sprueone
block parts sprueone
block and tackle build sprueone
scratch built block and tackle sprueone
block and tackle scratch built sprueone
Pulley wheels made from 2 upper return rollers then added parts from the turret bustle rack parts and tow cable ring.
Tamiya hull holes sprueone
Tamiya hull holes patched sprueone
^ yup, old Tamiya tank kit.
pre-primer sprueone
pre-primer sprueone
Next is primer to determine how much of a Glue Bomb this really is.
Thanks for looking . . .
Lol, I like it! Looking forward to more.
Interesting project, its looking nice.
I am glad Dragon has come out with the ‘‘Bergetiger’’. I plan on ditching my old CMK kit and getting the new one.
Gamera, Bish, Thanks for looking in and the compliments. Yes the Dragon kit, and I hear that it’s all around the best of the four available.
Looks like you got some serious work !http://www.laie-smileys.com/tijeras3.gifcut out for you.
This should be really interesting.
!http://i20.photobucket.com/albums/b232/gluetank/Animated/Disastermastermotion-3.gif
Looks like a great project, its coming along nicely. Robert
What a fantastic start you’ve done. I can’t wait to see more of your WIP of this build!
Toshi
DM, Robert, Toshi, Thanks for checking in and your comments. [:D]
Well, this is a tank build, so there are plenty of wheels…
tank wheels clean up sprueone
I don’t doubt that. I’ve seen that on youtoob a few times. They look bigger than the little ones we’d throw at each other as kids. The moist mud type are probably heavier too.
Before I left my nephew’s house, I sprayed a primer base of Rust-Oleum Camouflage Earth Brown. I’m hooked on the series of aerosol spray paint BTW.
Finally seeing this under the home bench lighting reveals spot that need attention.
primer and sanding sprueone
I’m trying some craft acrylics that I’ve never used before. I like them so far. Currently mixing the “rubber tire” color.
folkart paint sprueone
rubber color sprueone
in the shade…
in the sun
The cable position and tension is set and working on base color (on turret) for this rig.
sprueone
sprueone
I think I might move the rear stowage box onto racks and hang them over the rear deck a little more
I decided to relocate the rear stowage box. It’s mounted to a couple parts from the kit’s rear bustle rack and a couple fender support parts. Styrene sheet covers the bottom.
The overall green color is just the base coat before detailing and weathering.
rear spoiler cabinet sprueone
base color green sprueone
base color on tracks sprueone
turret detail sprueone
The kit vinyl tracks were base coated flat brown. Then after that dried, masked off and sprayed hot-rod primer. The masking tape is old so it left some adhesive residue behind. I’ll clean that off tonight.
Wow, I’d lost track of this.
She’s really coming along, I’m not totally sure exactly what you’ll have in the end but you’re getting there. [;)]
R
" . . . Lost Track …" [:D] Haha, good one! Thanks for checking in.
That is cool. I want to try and build one of those. Thanks for posting that!
!http://i91.photobucket.com/albums/k290/SprueOne/Fragezeichen/FragezeichenPatton-23_rbbrtir-shd_zpsdlvswcuo.jpg
A good choice of colors.
I think 'ya really nailed that wheel color.
I like messin’ !http://i723.photobucket.com/albums/ww231/2kfrc5/stirpot.gifwith those craft paints too.
LOL, I wasn’t even thinking about making a pun when I said that. I’m probably funnier when I don’t intend to be. [:$]
!http://www.laie-smileys.com/jeje.gif
!http://i6.ifrm.com/13499/13/emo/th_bump.gif
