Forward Airbases Metal Matting
does anybody know either where i can get (Or what i can use to make) the metal matting use on airbases in WW2 in 1/48th scale? i am working on building a p-61 black widow diorama and im at a loss as for what to use. i want to make the base look like a forward airbase that utilised the metal matting with holes in it instead of using boring dirt or black top.
Any suggestions helpful!
Search for 1/48 PSP on any online modeling store. Eduard and Verlinden both make bases, and someone out there (the brand escapes me at the moment) makes PE pierced steel planking.
Thinking about maybe picking some up to make a base for my P-51 WIP…
You mean 1/48 Perforated Steel Planking (AKA PSP or Marsden Matting)?
Never heard of it. [:D]
(These came from www.radubstore.com & www.bnamodelworld.com — there must be dozens of other sources.)
The Marston Mat was developed during World War II and was widely used in every theater of operations. Though rigid enough to bridge over small surface inqualities of the ground, it was used to best effect on stabilized subgrade. This combination provided an adequate semi-permanent runway. Some conception of the logistics problems of war can be gained from the fact that some 60,000 pierced steel sheets 15 inches by 10 feet are required for a 150 by 5,000 feet runway, weighing nearly 2,000 tons, requiring 35,000 cubic feet of cargo space to be shipped overseas perhaps ten or twelve thousand miles. A runway this size can could be put down in 175 hours by 100 unskilled men.
During Viet Nam, our photo analysts went nuts because they saw “USS” repeated endlessly on enemy airfields and other places where PSP had been co-oped. Eventually some more senior type told them “It dates back to WWII. It was made by United States Steel.”
You are looking for Pierced Steel Planking, as doogs said, aka Marsden Matting. I have used the Eduard PSP base in 1/72 and it has excellent detail and takes weathering quite well. Toms Model Works makes individual PSP photoetch pieces in 1/48, http://www.tomsmodelworks.com/catalog/product_info.php?cPath=22_28&products_id=53, but for that price you may want to consider one of the plastic bases. Here is how mine turned out:
Of course, if you really want to punish yourself, it’s only 87 holes per PSP plank … set yourself up a jig … and maybe a month or so of on again, off again work with a pin vice and some Evergreen strip would see you with a pile of homemade PSP. I know, my bad [6]
There are some printed on cardstock sources out there as well.
PSP was used in a lot of different applications. It was used as a retainer for building walls in bunkers and boat ramps. Laying the matting down helped prove a solid beaching area for amphibious aircraft, so they could taxi in and out of the water on sandy areas. It was used on river boats as an added layer of protection on hulls above the waterline.
Also as a recovery tool in sand/mud/etc.
You still see modern equivalents used in the offroading world.
Search for Hans Von Hammer’s method of making PSP with aluminum foil.
Hans’ method only works if you have a PSP base to make molds from in the first place.
It’s always good to be 2 moves ahead anyway. He’s got to buy some no matter what, but he’ll have some ready for the next psp base to do.
THe company “Just Plane Stuff” makes a resin 1/48 scale PSP and sand/dirt/gravel base that looks pretty good. The Eduards bse is just PSP all the way to the edges, while the Just Plane Stuff base is mostly PSP with a little bare ground along the edge. Great Models Webstore carries Just Plane Stuff for sure, but I don’t know about the others.
Instead of holes have pins. This can then be pressed into a uncured modeling medium that will take the pattern. Not the easiest yet affordable.
Now you have a ‘master’ PSP press that can lay miles of 1/48 scale runway for less than 1 sheet of PE.
