For rigging wire,,,What thickness do you use for 1:350 scale modern ships
Just curious…on a 1:350 scale ship,what thickness would you use for rigging.
what is also the best material. Is sewing thread good,because it seems that it would not look real.
I was looking at using metal wire…just needed the thickness
Go to the local sporting goods store and look at the fishing line selection. Everything down to 1 pound line which is about .006" diameter as I recall. On 1/350 scale ships I would say the thinner the line the more accurate the look. You can use the “blown out match” technique for tightening the line after installation. Don’t use wire. It will kink and fail to look real. Don’t use thread, it will fray. Although Nylon thread is as good as fishing line.
Good luck.
Dennis.
I use a very fine thread, a light to medium gray in color. While it is shiny when new, steel cable oxidizes and gets dusty and dirty quickly. It turns to a gray color. It is getting harder to find really thin thread these days, but some specialty sewing shops still carry it.
For 1:700 I use that clear monofilament stuff. Absolutely miserable to work with, but it looks neat.
It is very hard to get rigging to look thin enough. Scale size is almost unobtainably thin. So, reducing contrast is a trick to make it look thinner. Do NOT use black or white. They stand out too much and look thicker than they really are.
