Floquil paints
Are they acrylic or enamel? My bottle of gloss black doesn’t even say what you should use to wash brushes that have been used in the paint with.
I believe they are lacquers unless they have changed.
So, does that mean they should be cleaned with mineral spirits? Thanks.
No, that means they should be cleaned with lacquer thinner.
Mineral spirits may or may not work, I have never used them.
Lacquer thinner should only be used to clean brushes while using floquil
Chris
I would consider finding a different paint for brush painting such as Polly S or an equivalent acrylic.
The lacquer thinner is going to cut the life of that brush down real quick!
Thanks for the responses. I see what you mean by suggesting that I get another type of paint; I’m not too fond of enamels/lacquers myself, but this bottle was real cheap compared to Tamiya Acrylics or Model Master Acrylics. Thanks again!
If you have to buy brushes because the lacquer thinner destroyed them quickly then that paint just became much more expensive than the other’s mentioned. [;)]
The old Floquil paints were laquer based. Early formulas will eat more than your brushes. Unless you used a “barrier” that was sold by Floquil, paint straight from the bottle would attack the plastic it was painted on. I found this out the hard way when i used it on an inexpensive piece of plastic rolling stock. I think Floquil was orriginally formulated to paint metal model railroad equipment where a strong carrier was needed to etch the metal for hold. It was a great paint with very fine pigment but the carrier is very volitile and you really need a good respirator and good ventilation when you use it.
Herb
