I was just wondering if anyone would have ideas or tips on getting a flat finish once I have sprayed Vallejo Model Air on my SU-100? As you probably know, when you airbrush Vallejo Model Air it dries with a satin finish. I would like to get it almost dead flat if possible.
Any particular flat varnishes/finishes you use? Also, would Testor’s Dullcoat work (would prefer acrylic if possible though).
Not all the Model Air colors dry in a satin finish. I recently finished a model that I airbrushed with Model Air flat black and it dried dead flat. But, like Chrisk-k suggested I’d use the Vallejo matte varnish since it is acrylic.
Chris, how do you apply it to get a dead flat finish? Do you apply several light coats to get a flat finish? If so, how long do you wait between each coat? Or is there another way that you do this.
I’m not sure if this is it,but i use Vallejo Acrylic Resin Matt Varnish 70-520,if this is what you got,I dn’t thin it at all,I spray it straight from the bottle no problem
I mix 2 parts Poly U Vallejo matte varnish with one part distilled water and add a drop of Flow-Aid. Then, I spray @ 25 psi 6 inches away from the model. I apply the 2nd coat about 5 minutes after applying the 1st coat (it dries very fast). Some people at Armorama spray unthinned Poly U Vallejo matte varnish.
Vallejo makes several different matte varnishes. I have only used Poly Urethane matte varnish and it works like a charm.
