Fixing resin issues
I bought a set of the Goffy resin parts to upgrade the Revell 1/144 Tornado. My issue is that the cockpit tub is slightly warped and will not fit correctly. I’m pretty new to resin so not sure if there is a way to straighten it out. Ideas?
Going to take heat to fix… Either with a blow dryer or hot HOT water and gentle tweaks, Even then, no guarantee you won’t wreck it… Resin’s brittle as all get out…
