First peek in the box: Airfix 1/48 Spitfire Mk IXc/XVIe
Though it’s been 20+ years since I built an Airfix kit, the news of their appearent demise kicked off some nostalgia to build some Airfix kits. Much to the delight of my credit card company, I’m single-handedly trying to resurrect Airfix. Just this week I bought the 5 plane, 1/72 70th Anniversary Spitfire kit, a Spitfire 1/48 Mk V/Seafire Mk III, and the one that arrived today- a 1/48 Spitfire Mk. IXc/XVIe.
My last Airfix kit was a B-26, which I built around 1982. I don’t recall much about it, other than I thought it was a reasonable kit, though a bit thin on detail. And most of what I read recently has been about poor fit, raised panel lines, etc.
So when I opened the Spitfire box today, I was pleasently surprised. The box is chock full of sprues, with a huge number of options- some not even documented in the instructions. The options in the instructions provide for the rounded and pointed rudder, 3 gun/wing configurations, and two cowl options.
After comparing the sprues to the instructions, I saw that there are not only normal and clipped wing tips, but the HF wingtips also. And for some reason, there is also the lower wing for a Mk. V.
All of which means if you’re willing to do a little research and maybe a bit of sanding, I bet you could make quite a few variants out of all the parts.
The plastic feels neither soft nor brittle- it’s a bit different than most kits I’ve handled. It feels like it will work well.
I’d heard how older Airfix kits had raised panel lines, but this is obviously a newer tooling, with finely recessed panel lines. The lines in the Mk. V underwing are a bit deep, but nothing I’m sure flowing some Future into the gaps couldn’t cure.
The office is nice, with a decent IP, nice seat, seperate throttle quadrant and oxygen bottles- all of which look like they’ll build into a nice office. The interior sidewalls have raised detail, that though a bit sparse, is quite adequate for most folks who build mostly OOB (like me.) One oddity I noticed- the rudder pedals are molded in to the “suspended” floor, and are basically small blocks. Correcting this would require some simple scratch building, but as they probably won’t be visible except under close examination, I’ll likely leave them alone. The cockpit door is molded in, but Airfix thoughtfully included a seperate door, allowing you to cut out the molded door and open the cockpit up.
Two types of wheels are included- flat faced and four-spoked, and there are two slightly different propellers. The instructions are plain but clear, with adequate painting instructions. (If you’re like me, you’ll do more referring to photos than instructions for painting.) Markings for 3 aircraft are provided, with a large set of common decals for all the little stencil markings. The color is good on the decal sheet. Another nice point is the included slick color sheet showing exterior colors and decal placements.
The clear pieces are a bit thick, but adequate. I tend not to sweat stuff like that, so for me it’s not a problem.
The only real complaints I have is the sprues and their connection to the parts. Some of the sprues are veritable tree trunks, with huge connections to the parts. Careful cutting and sanding keep it from being a problem, but I’d certainly prefer not to have to deal with it. Also the wing and tail surfaces seem a bit thick on both the leading and trailing edges, and the prop seems a bit mis-shaped, when eye-balling a picture for comparison.
Overall, I’d say from just examining the parts, I’d recommend this kit. While the engineering and detail are not what you nornally see from Tamiya or others, the fact that it was only $16 US makes it a real bargain.
After seeing this kit, it really makes me hope someone will buy the Airfix brand and continue producing more kits like this, and keep the variety that Airfix has been known for. If I’d have known how nice these newer Airfix kits were, I’d have already bought more. Who knows- maybe that would’ve helped?
Hey buddy,
Thanks for the kit review. I think maybe I’ll start a search for acouple. Believe it or not I have no Spits in my stash. Funny isn’t it you don’t really realize a good thing until it is gone.
Thanks again
Zip
Try Squadron- that’s where I got this one. They have that one and a Mk. 22/24, which is also supposed to be a newer mold, and I’ve read good reviews on it.
This kit was reviewed, not all that favourably, in the September issue of FSM but it has been much better received elsewhere. There are enough spare parts to produce any Spitfire from a HF Mk VII through LF and HF Mk VIIIs to early, mid and late Mk IXs. The kit also contains the sprues for the upper and lower wings of the recently retooled Spitfire Mk Vc/Seafire Mk III. Why? Well I can think of one reason. The wings for the Mk IX include the tyre clearance bulges that were only found on post war aircraft. In most cases these will need to be sanded away. Alternatively you could fit the upper Mk Vc/Seafire wing halves to the lower Mk IX wing.
The props look like they have planks for blades. The FSM reveiwer used a Hasegawa prop. Ultracast have a large range of goodies mainly for the ICM Mk IX but many of them might be useful for the Airfix kit and you should be able to get suitable replacement props from them.
MH434. In early 1944 it did not have the large Aero Vee universal carburettor intake as supplied in the kit. You need to replace it with the earlier, smaller intake sourced from elsewhere (e.g. Airfix Mk V). Nor did it have the outer cannon stubs so you need to fill the holes for those. (This Spitfire is still flying today with the Old Flying Machine Company at Duxford.)
Wow… shows how bad my memory is. I pulled out that issue and danged if I’d already forgotten reading that. They say memory is the second thing to go. Can’t recall the first… [;)]
Haven’t built it yet, so I don’t know about fit issues.
I tend to be fairly forgiving about kit’s problems. I guess I wouldn’t make a good reviewer. (Or maybe I would… “The Easy-To-Please Critic”)) I guess I’m a “lazy modeler”… if I have fun building it, that’s the main thing.
Thanks for that great info on the various versions and extra parts. I figured some folks here would know how to make use of those parts!
I built this kit when it came out a couple of months ago. There were large gaps at the wing to fuselage. The trailing edge of the wing is much too thick. The prop is a joke I replaced it and the spinner with one from a Hasegawa kit. The wingtips do not fit the wing. I had to do so much sanding to the wing I had to rescribe it. I didn’t realise the gear bulges on the wing needed to be removed till after I painted it so I left them. Here is the finished product.
Looks great, mkhoot!
I read a build report by Brett Green that showed how he used a spacer to hold the fuselage open a bit wider (just forward of the cockpit), and that took care of the wing root gaps. I’ll give that a try.
Your pics show that with some work, it’s still a great looking kit. It’s a nice looking Spitfire!
Hi Jon,
I have built the 1/48 Seafire III and the Mk.22 Spitfire kits, the Seafire is a real patch work job but you can make something decent out of it -just do lots of dry fitting. As for the Mk.22, its a real corker of a model to build. The office is a little sparse, however the airframe is well detailed with fine engraving and would’nt be embarressed standing next to a Hasegawa kit. Here’s what I did with mione a couple of years ago:
I also have the new Mk.IV kit in my stash, will be building MH434 when I get around to it. Looks like a decent enough kit with a bit of work put into it. Good luck with your builds and keep us posted.
Darren
Hey guys,
Couple of nice builds there. Even though the kits were not the best at fit, your modeling talents still brought out two very fine looking planes. These are the ones I take pride in the most. This is what I mean when I talk about saticfaction in modeling. Anyone can make a Tamiya or a Hasegawa look great but take a good ole Revelagram or Airfix and make them come out like your higher end models and that is satisfaction. You should be very proud of these builds guys. They really show off your skills. Like I said guys, nice looking planes. You should be proud of them.
Thanks
Zip
That looks great Darren. I was going to acquire that one, too, but my wife asked me to let the credit card cool off for a day or two. [;)]
You did a really nice job on the weathering- looks great.
I’ll definetly be posting pics as I progress.
