I normally build Aircraft. That being said, I wanted some diversity in my collection and to try something different. However, I only build in 2 scales. 1/48 and 1/72. There isn’t much in 1/48 so I decided my first venture into Armor will be in 1/72. I am fine with small parts, so I am not sweating that. Anyway, for my first two kits I got a Trumpter M1A1 and M2A2.
I want to build the Bradley with all the hatches open, because it does have an interior. I am just really new to this armor thing.The tracks on both kits look like a continuous strip of vinyl, which given what I have read on here that is a good thing for ease of use.
A couple questions though
How does everyone mate tracks to wheels? Do they get the right sag on their own or is there a trick? I have also noticed people painting the road wheels after attachment to the hull. is there a trick to this? Also, I am guessing I will need to paint the tracks, what is the easiest method to get a halfway believable look.
For extra points… Anyone know of some good 1/72 modern tank and infantry figures?
How would you tell? The return path is under skirts! I’m pulling your leg… there is NO significant sag on either vehicle for any I’ve seen. If you want sag, go Soviet. I’ve got this 1:72 IS-3 in my queue…
Vinyl tracks typically have pins on one end and holes on the other. The pins are inserted throught the holes and melted to make them too wide to go back through the holes. Some newer kits have tracks that can be glued with model cement. I’m not familiar with the small scale Trumpeter kits. Vinyl tracks are usually long enough to fit snug on the wheels without any cement. Track sag isn’t an issue on the two kits you have because they both run with a tight track. If you want sag there are some tricks to getting vinyl tracks to sag, but the easiest way is to use individual link tracks or link and length with the sag molded in.
Roadwheels are a pain in the butt most of the time. There are about as many ways to do them as there are modelers. On a brail scale kit you might try using a dark heavy wash on the road wheels rather than trying to paint the little devils. The tracks on both your kits have metal and rubber parts. The rubber would be a gray black color and the metal can be anything from rust red to shiny steel depending on your operational setting. Try doing a search on the internet, there are tons of color photos available to give you an idea of what they should look like.
