Pete, Well I guess it was worth a shot. I looked around online trying to find a build review of the Encore kit and can’t come across any. Later on today I’ll break open my kit and do some test fitting and see what I come up with.
Kiwi The Dragonfly is looking pretty good. Like you said the tan looks a little light, but the future coat will darken it plus weathering. I know its too late now but what I found helps for painting soft edge camo is silly putty.
You can buy it for under two dollars. I used the Spitfire as a test bed for the putty, had a little running underneath but I had my paint a little to thin. The putty was put directly over unsealed Tamiya acrylic but it didn’t pull any of the base coat up. The model is 1/72 btw.
I spent some time yesterday fiddling with it. I’ve been sanding, test fitting, sanding some more, test fitting some more etc. It’s almost there. I think today I’ll be able to get it to fit nicely. And looking ahead a few steps, the canopy frame and windscreen will pretty much hide any little gap I may end up with.
For Southeast Asia (SEA) camouflage colors, I am pretty sure the USAF used the same colors on all of their aircraft. For us modelers we use the FS (Federal Standard 595) colors. These numbers are 5 digits long. The numbers break down as the following:
The first digit represents the finish. A “1” is gloss, a “2” is semi-gloss, and a “3” is flat.
The second digit represents the color category. 0 = Brown, 1 = Red, 2 = Orange, 3 = Yellow, 4 = Green, 5 = Blue, 6 = Gray, 7 = Miscellaneous (Black, White, etc.), and 8 = Fluorescent.
The last three digits represent the shade of the color. This is measured as a “reflectance”, meaning the percent of incident light reflected from a colored area. The higher the number, the “lighter” the color.
For example, the tan color you are looking for in FS is FS30219. You notice that the first digit is a “3”. This means it is a “flat” color. The second digit is a “0”, which represents the color Brown. The last 3 digits are “219”, which comes up with the shade of brown.
Here is a link to a page that has the USAF SEA FS colors for most brands of paint:
According to that chart, for the tan color you should use FS30219 which is XF57 in Tamiya paint. The medium green should be FS34102 which is XF65 in Tamiya paint, and the dark green should be FS34079 which is XF13 in Tamiya colors. It doesn’t show the Tamiya color for the light grey but on another chart the FS36622 should be XF19.
Pete, Glad to here that you almost got that gap gone!
Tim and Ken, I remember looking at the Cybermodeler link for the Tamiya paint matches for SEA camo. It was my experience that XF-57 is way to light and XF-65 way to dark. When I paint another SEA camo with Tamiya paint’s, I’d use XF-52 lightened for the base coat and XF-5 and XF-27 for the greens.
Greysnake, thanks for the advice on the silly putty. I’ll get some next time I’m at the store. That will work much better than my blobs of tape I’m sure! Looks great on the Spitfire for sure.
Ken, that’s awesome about the paint. I had no idea that that’s what the codes meant. Very cool. The dragonfly was a very old kit and it literally just said ‘tan’. I had Tamiya ‘deck tan’ and it was obviously much too light. I might actually go back and repaint it because the kit actually looks great, if it weren’t for that color! I threw the kit together in an awful hurry but I don’t regret it, it was very therapeutic at the time and I got it very cheap.
I’m about to go back to my Skyraider I think too. I walked by it this morning and kind of got excited about seeing it painted up in USAF colors, now that I know what those colors are!!
I’ll also be making a start on the F-102 this week. I guess I can add that to the group build too eh Ken? I need to do a good job of this one as it’s for my best friends office and he makes parts for Boeing so if there are mistakes he will call me out for sure!
Thanks. Just some more advice on the Silly Putty. I’d make sure the maker is Crayola, since that’s the only brand I’ve used. And I don’t know if other brands would have a different formula and attack the paint. Also when masking around small parts be really careful! It can basically swallow them up. So I’d be careful around PE. When airbrushing the camo make sure you are using a low PSI and not spraying at an angle, or you risk ruining the base coat. When taking the putty off make sure the painted putty doesn’t come in contact with you’re nicely painted model, since it will transfer the paint to it[:@] The putty sticks like crazy to blue painters tape, handy if some of it is being stubborn or a piece of fresh putty will pull it up. Also I don’t recommend reusing the putty since the putty can transfer the old paint that’s on it to a new model.
Another masking trick that I haven’t used, but people have a lot of success with is Blu Tac by 3M. Its mainly used for hanging up posters and a lot of guys seem to swear by it. From what I gather you roll it out into long snakes and put it where you want the camo outline. And then fill in rest of the spots to be covered with paper towels.
As for the New Year I’ll be going to work like always.
You are most welcome about the info, glad to pass it along.
For New Years we are having friends over to watch the ball drop. We usually play games until then. But a sign of getting older, the party usually is over once the ball does drop!
I have never airbrushed enamels, why do you prefer it? I do a lot of my fine brush detailing with enamels after, I think it was you, mentioned that it doesn’t eat the acrylic undercoat. I like them in cockpits especially as it’s so much easier to paint small dots and surfaces without the wet runoff or difficulty mixing them thick enough to stick. How are they to airbrush? Do you use a thinner? They must smell pretty bad?
I’ve been tinkering with the F102 for my friend. It’s the old monogram kit and it’s actually really neat. I had no idea what a big plane it was (after building the F104). I guess I just assumed that it was smaller but it’s at least as big as the F14 I just completed. I’ve picked up another identical kit for myself and will build them side by side. Will try and chip away at the Skyraider at the same time - I guess the Syraider will give me a chance for redemption at the camoflauge colors after my Dragonfly debacle. Still, as soon as my silly putty arrives I might give it another go. I really like that idea, must be able to make super fine lines.
Again, happy new year everyone! Probably a quiet one here, in bed by 9pm so can get up early and ski tomorrow!
There are few reasons why I prefer enamel paint. First, when I started building models as a kid, enamel was the only kind available. I am showing my age here, since it was around 1963 when I was 6 years old. When I picked the hobby up again a few years ago, it was easy for me to refer back to the same paint.
Second, enamel does not dry as fast as acrylic. This makes it easier (at least for me) to airbrush. You can get a smooth finish and don’t face the same problem as what you encountered with the “rough” finish from the paint drying before it hits the surface.
Third, I have more experience with enamel paint from painting automobiles (the real ones, not models!).
But a lot of people prefer acrylic, it is simply a matter of personal choice, not that one is truly better than the other.
And yes I do thin the enamel paint. I use Model Master enamel paint, so I use their thinner. And again yes enamel does has a strong odor, but I use a paint booth that ventilates the fumes.
Thanks for enamel beta Ken! I’ll definitely give it a try. I was at the LHS earlier today and they have a nice selection of model masters stuff so I’ll be sure to let you know how it goes after my practice F-16 gets yet another paint scheme! Little more work on the Dragonfly this evening. Some decals applied, they are old and horrible and wrinkly and turning white so I drowned them in micro-sol/micro-set and we’ll see what happens overnight I guess. The plane looks better now with some future and decals, I’m actually looking forward to weathering and displaying it. Also made a good start on my F102, getting some parts ready for some paint in the next few days when I have time to get my airbrush out. It’s actually a very very simple kit with not too many bits, unlike the F14 I just finished which has fifty trillion pieces. So far it looks nice and solid and after cutting off more flashing plastic than I’ve ever seen, looks like it should go together really nicely.
Tim, At least you had better luck on your decals, then I did with mine on the 105. Looking good so far!
As for me I might add another build soon. Thinking about getting some decals for my F-101. But will see right now I have almost five builds on the shelf and other two waiting!
Well Ken I was all excited about the 101, but the one I have is the interceptor[bnghead] I thought for sure I had the RF-101 in my stash. One Monogram RF-101 is listed on ebay right now. But since I’m blowing my model budget for the month on an Airfix Sea Vixen I’ll have to let it go.
Yes, if you were intending on building the F-101 for this build, it would have to be the RF-101C. There are several Hasegawa 1/72 RF-101C on eBay, but I don’t know if you build that small in scale. The only choice presently to build a 1/48 RF-101C is to use the Revell 1/48 F-101B and a conversion kit. There are a couple available.
The more expensive one is a resin kit made by C & H Aero Miniatures which just sold the molds to Mike Moore of GHI Models: http://www.ghimodels.com He has not started making any kits yet so currently they are not available. But according to his website he will start re-releasing some of the kits he purchased beginning with the A-1E Skyraider next month.
The other alternative is the vacuum formed conversion kit made by Koster Aero Enterprises. His kit is less expensive than the C & H Aero kit. Bill Koster does not have a website but there is a site that has a description and contact information: http://www.swannysmodels.com/KostersKorner.html
Pretty soon Kitty Hawk will be releasing their 1/48 F-101A and rumor has it that they will eventually release a RF-101C. In fact, I am seriously thinking about starting another group build just for the Voodoo when they release the F-101A. It will be for all versions of the Voodoo.
Ken, thanks for all the info! I don’t mind building in smaller scales so the Hasegawa kit is a thought. Plus it looks like it can be hand pretty cheaply. Don’t think I want to tackle a resin kit just yet. I wouldn’t mind the 1/32 vacuum formed kit. But my aircraft hanger space is limited! I’ll just keep an eye out on ebay for the Monogram RF-101. My goal one day is to have the entire century series line built in 1/48 for every version of the aircraft. So I’ll have to get it one of these days anyway.
Another one I’m looking at is the Monogram A-1H Skyraider. My dad built one when I was really young and I really liked how it looked. So I might snag one in the next couple weeks.
I thought I would share pictures of my latest acquisition. It is a decal sheet made by Caracal Models for the F-5A and F-5C. I will be using the markings for the Skoshi Tiger evaluation program:
