Presenting a pair of Russian Sentries I’'ve had going on the bench for a little while, both getting pretty close now. Thugh pretty similar, these two are just what I need standing guard in an upcoming scene.
Here’s the 2 kits
Having started these a while back, sorry I don’‘t have the ‘‘sprue’’ shots,but I’ll tell you that all TaNk’‘s figures are extremely well cast… on the order of 2nd only to Alpine in neatness and lack of flash, troublesome seamlines and crud other makers stick you with. The medium grey resin used however stinks to high hell and will have you sure to get into your full Bio-suit for paint prep work…but, you’'ll see the pride these are made with as you remove the very well-formed pour blocks.
Here’'s a couple pics of the 1st chap assembled OOB on his block
[You may spot some putty temporarily holding on rifle & head]
Actually he’'s been kicking around on my bench for quite a while!
then…
So time to get painting~~~~~~ :mrgreen: ~~~~~~
THE HEADS~
Unbelievable, but I liked the kits head! Has a good look to him I think & maybe even a Russian look? (Perhaps that of another State?)
Certainly has that stiff-upper-lip, stalward thing going…
Work done with W&N oils over acrylic base, much in the way of my other figure blogs, though I believe I may be continuing to improve.
Here’s he’s about set,
with warmth added to mouth and ushanka completed
The 2nd figure got a Hornet replacement head, mostly because I wanted him in the ushanka cap as well, & the kit head was maybe not-so-special. These heads are so good my resolve to use other brands is lessening every time I paint one–I’m started to get why nearly every great 1/35th painter chooses these Roger Saunders’ sculpts
Painted in the same formula as above, but with a bit less paisty complection and the 5O’clock shadow added using the old figure painter’s convention of a bit of Payne’s grey mixed into the flesh colour.
I call him "Ringo’
Here he is basically completed
One of my favorites I’ve painted so far—
-I’d love to hear what you guys think!
More coming soon to a monitor near you!
