Ok, I am nearing the end of my Condor Legion 109, so I decided to crack open an Eduard Fw-190 D9 in 1/48. Deep breath.
Another deep breath.
I thought I’d be cute and do the thing closed up and ignore all the innards forward of the firewall, behind the engine.
But I realized that the landing gear bay on this one doesn’t have the normal cover (it’s a late model), and you can see all those innards from the bottom. D’oh! So I built it up and will paint the underside bits so there’s something to look at should any jerk ever shine a light up there.
My biggest concern is the wing root cannon bay fit. In short, it’s a terrible engineering decision, but Eduard knows that, so I won’t rake them over the coals here.
How I dealt with it:
Well, I could open them, but I don’t want to. So barring that, I added the cannon bay doors to the fuselage and glued them down, holding the wing in place to ensure proper alignment, if not perfect fit.
Next step was to add the upper portion of the wing to the fuselage. I’ve never built a plane this way before, but Eduard provided a pretty hefty connecting tab that actually makes this not so awful. I began by gluing only the front portion of the wing in place after cutting away all the parts where the cannon bay door will cover. I did not elect to use the supplied internal parts, as I saw no way that they would help.
Once dry, I glued the cannon bay cover to the wing at the forward-most joint, then got it as level as I could. After that, I worked my way down the wing, eventually gluing all but the rearmost part of the cannon bay cover.
Finally, I glued the rear portion of the wing to the fuselage.
Next, I added some sheet strene to the bottom of the cannon bay door from inside. This is just so the putty I will force into any remaining gaps will have something to push up against and not just fall inside the wing and annoy me.
So here we have my current progress, coated with a quick spray of Mr. Surfacing Primer 1500 Black.
As you can see, there is some work to do, but it shouldn’t be insurmountable.
If it is, I’ll fly it right to the trash can and buy a Tamiya Dora, even though I think the Dora is one ugly aircraft (especially compared to the awesomeness of the Antons).
-BD-
