I’m working on Trumpeter’s 1/32 A-7D Corsair and the instrument panel is made of film andI guess It’s supposed to be trapped in between the clear part and the plastic part. Are there any suggestions to complete this part of the model?
I’m just guessing here; however, I’ve seen a similar thing with a few kits I’ve purchased. On the ones I have, its a clear piece of acetate filme that gets sandwiched between a photoetch metal front and the styrene (or resin) part for the cockpit. Small drops of CA is what I’ve found to hold them in place the best.
I have made my own of this type where the kit only gives the styrene panel.
I first drill out the instruments with a small drill. Then I scan the styrene panel to show exactly where the instrument holes are. This provides a template for some computer artwork. I have spent some time looking for images of various types of aircraft instruments- airspeed indicators, altimeter, attitude indicators, compasses, etc. I keep a whole folder of them, both white faced and black faced instruments.
With computer editing software, it is easy to resize for each popular scale the instrument images saved from internet. I then paste a copy of each instrument onto the template I made (the scanned image of the panel. If you paste each where the hole is, you end up with a set of instruments in the right spot. I then print this array of instruments on glossy photo paper, cut it out and glue it to the back of the styrene panel.
I am real tempted to try this, Don.
I’m working on a Hobbycraft Bell YP-59A Airacomet in 1:48. The decals for the instruments are very rough. I’m also not looking forward to applying the decals one by one.
I have two of the Squadron resin cockpit kits, so if I mess one up, I have another instrument panel. My only concern at this point is the thickness of the instrument panel. Those guages might be a bit recessed!
Thanks for the idea. It has merit, and I’m very tempted to follow through with this idea
