Fiat Br 20 color scheme?
Fiat Br 20: could someone suggest a ref for colors/markings? preferably something not spotted?
What do you want, Japanese or Italian?
The references are hard to find, but getting better. Here are some.
http://pacmodelscatalog.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=PCM&Product_Code=AD23&Category_Code=ad
http://pacmodelscatalog.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=PCM&Product_Code=sky_72019&Category_Code=sky_d
I have others at home which might be out of print, including the old Profile Publication on it. These include a two volume set, The Sky Decal set is very good with a good assortment of possible markings.
Mike T.
thanks to both of you. i found a side and top view of a japanese version, really like the style,
Good luck with the kit Bujinin. I have two in my stash with the RCR PE sets. The Japanese purchases were earlier versions if my memory is correct. The Sky Models decal sheet for Italian bombers has some good versions as well.
One of the poosible historical oddities would have occured over Shanghai. Japan was using these FIAT Br 20’s while the Chinese defenders had a small number of FIAT CR 32’s. I don’t know if these aircraft ever flew against each other in that theater.
Mike T.
