Ferrari Daytona Shooting Brake [FINISHED]
It can’t be an FF since it’s two wheel drive…
Or would it be a 365 GTB/4 Kammback? (It’s actually based on a rebodied Corvette.)
I started with a sealed kit of the Miami Vice roadster; the deck lid and right side door were scarred from one of the tires. 90% of the deck damage was fixed by cutting off the deck. Guess it was destined for this idea… The rest was filled and sanded out.
About ½ inch of the leading edge of the soft top was used to mate to the windshield frame. The Gremlin roof was cut down height-wise and lengthened. The sides of the roof were reshaped and refined with strip styrene and filler.
I changed the shape of the rear window and added trim.
Instead of using the glass as the hatch I removed the hinges and scribed in new panel lines Like a Vega Kammback.
Many wagon conversions suffer from poor tailgate/hatch design. To try and negate that issue, and to keep the theme of the original car, I integrated the Daytona trunk line on the back panel.
Getting close to adding the B pillar…
Sorry dude, but, it reminds me of a Gremlin! [6]
When I built the Gremlin kit a few years ago I wasn’t impressed with the soft and uneven molding of the body detail behind the quarter windows. I sharpened it up on this one with a couple strips of styrene.
And a simple B pillar.
Now! That is something ya don’t see every day!
Cool, nice proportions!
Thanks guys!
To make the rear windows I used the Gremlin tinted pieces. I trimmed the back one down and cut the side windows out of the windshield.
Scale-Master, I like what you are doing with this build. I sometimes think about a similar build, I just don’t know if I have the skill to pull it off. I feel that a first generation Mustang station wagon is an attractive car. The Mach-E just doesn’t come close. I’m looking forward to seeing your finished build. I know it will be something to see.
BTW: I am taking notes.
Great start on this one SM!!
Thanks Guys!
That Mustang is a good example of what I was describing as poor tailgate/hatch design.
I cut the rear off the Daytona interior and the front off the Gremlin’s and mated them together. A decent amount of putty was needed to smooth the transition on the inside, but the AMC part fit into the Chevy frame like it was designed to do so.
A Grerrari, now that is something you don’t see everyday. Keep up the good work!
I went with a Navy Blue undercoat for the Metallic Blue final coat. When I decide what shade I want to use…
I wanted a dark metallic blue, but this may be too dark…
I’ll think on it a bit.
I added texture to the blue paint to “carpet” the blended area of the two interior pieces.
The dash was hand detail painted and the gauges are decals from the Scale-Master '78 Pace Car sheet I drew for the Revell-Monogram kit.
The wheels and tires also benefitted from the same Corvette decal sheet.
I used the crossed flag logos for the center caps too.
The front half of the interior is box-stock except for the addition of the console and steering wheel decals from the same Pace Car sheet.
I went with a full coat of Deep Metallic Blue to brighten the near black Dark Mica Blue.
In the UK it was called the Ferrari Breadvan when it was first released.
Actually shooting brake is an old horse and buggy days term.
The 1962 Breadvan you reference was a one only racecar and not really a shooting brake, but a very cool machine. Typically they are are street cars.
Many makes and models have shooting break variants, although it is a predominately European configuration/name that came into fashion about 100 years ago.
This one is made up and actually a Corvette. I guess it could equally be a SportsWagon or Kammback.
The engine and chassis are straight out of the kit; very simplistic, not too detailed. Since this one is more about the exterior I left it all as is and added the underhood decals from the '78 sheet.
