I am working on my third build, F-18E. After studying pictures, I can’t really tell if the two color paint scheme is a hard or soft edge. I did a hard edge on the F-22 that turned out fairly nicely. Just not sure how to get a soft edge done.
If someone would be so kind as to point me to some accurate tutorial to paint a soft edge camo line, I’d be grateful.
Cut your mask from a piece of index card and raise it from the surface using a bead of silly putty/poster putty/rolled up sticky tape. Spray perpendicular to the mask.
I did my first ‘hard’ edge on a Tamiya Spitfire. I robbed my wifes supply cabinet and used Elmers low tack removable adhesive putty. Here’s how it went:
sausages applied, and tamiya tape in the gaps
Paint applied over the base
Pulled the masks and - pretty happy with the results!
The elmers low tack stuff is great. No residue, easy to use.
