The intent of this FAQ is to summarize, especially to newcomers, the thoughts and experiences of the posters to this specific forum, and such should be kept in mind.
This is a work-in-progress, and will be updated and revised continually. If you see anything that needs revision, please e-mail me.
Read and heed!
edit: Safety section added 5/1/04. I regret not adding this section at the onset.
SAFETY
One of the critical points new modellers overlook is safety. Regardless of how small a project may seem, or how minor the fumes, safety should be a priority.
The key element to a good modelling session is safety. Let’s run through the elements necessary to prolong your experience:
Ventilation
It cannot be stressed enough that ventilation is the most important safety precaution one can take. The preferred situation would be a steady airflow away from the modeller, towards the project, exhausted from the room to the outside environment (filtered, of course. I wouldn’t do to kill off your friendly neighborhood tree-climber with your hobby). Most of us, however, do not have this luxury. As such, there are steps that can be taken to help.
A simple solution would be the use of an inexpensive box fan, found at Wal-Mart/Target/etc, placed in front of an open window. This would permit the flow of noxious cheicals to be exhuasted to the outside environment. To be further environmentally-conscious, a simple, inexpensive (and I mean CHEAP) filter furnace can be placed in front of the fan to filter the vapors. Note, your project needs to be between you and the fan to be effective.
Another possibility would be the use of small fans to force the fumes away from the modeller towards an exhaust source.
A couple of further safety tips to keep in mind with ventilation:
a. You are working with noxious, highly combustible chemicals.
b. Be aware where those fumes are being exhuasted. Saving yourself and killing your roomate/family with the fumes will be counterproductive.
c. Airflow needs to be continuous.
Respirator
Some consider this an optional item when modelling (including gluing).
UPNORTH would remind us otherwise:
Further, Styrene has an excellent ‘tutorial’ for beginning respirator users:
For further details on respirators, read this thread
PAINT
First off, how about a nice discussion about paints in general? Murray Kish has this to say:
Acrylic or Enamel?
This is an ongoing debate, which will doubtfully be settled. The choice of which to use appears to depend upon the media being painted (plastic, resin, etc.) and the the tools to be used (brush, airbrush, etc.).
Enamel
Positive:
Model Master Enamels (billc3207):
Negative:
Acrylic
Positive:
Easy to thin (water)
Easy clean-up (water)
[Airbrush]Can be used straight from the jar
In some cases, thinning is only desirable to control drying time. This is crucial in the when using a brush to prevent brush marks on the model
Negative:
Tamiya & Gunze Sangyo require their brand of thinner
Pastels
paackerson:
upnorth:
How to apply yellow or white paint
“Yellow is one of the hardest colors to get good coverage with along with white. The first thing to do would be to lay down a primer coat of white or light gray. This will lighten the background and reduce the number of coats that you will need to apply to get a nice, even color. As far as it pooling along the edges and raised detail, try and lightly sand the edges to try and knock down that little ‘lip’ that always occurs along the edges. Lightly scuff the rest of the parts as well with some 400 or 600 grit sandpaper, being very careful around any raised detail. Roughing up the surface, along with the primer coat, will help the paint to adhere better and level out which will help with the build-up along panel lines, details, etc. The only other thing is to put the paint on in light coats and slowly build up the layers gradually until you get the coverage you need. Wet sanding in between coats can help as well. Hope that helps you out.” (heylonghair)
Tamiya Acrylics
“My Tamiya acrylics were hard to use also till i figured out that when your using them you should have minimal air flow in the room and they take a while longer to dry. also have a cup of water handy so when the paint gets to thick on the brush and starts leaving that rough brush look, you can just dip it and clean it and then start again.” (Airbrush)
“I found the Tamiya acrylics are better for airbrushing, I would try enamels they are far better for hand brushing.” (Colin)
FUTURE Floor Polish
Yep, you’re seeing that correctly: FUTURE floor polish. Think of it as cheap clear-coat.
Washing
(leemitcheltree)
AIRBRUSHES
Generally speaking, airbrushes, like any other aspect of modelling, are personal preference. Some use only one brand/type of airbrush. Others use a plethora of brushes, each for a specific job. No one airbrush is THE airbrush to use.
First, a quick listing of places to purchase airbrushes:
Great Models
-Excellent source for airbrushes and accessories, very good pricing
Squadron
Bear-Air
Hobby Lobby
Excellent stock, watch for sales of 50% airbrushes and paint
Michael’s
OK stock, a good source using one of their 50% off coupons (single item), usually found in the Sunday paper
Next, to make any kind of informed decision about an airbrush, you need to have an idea what an airbrush can do for you, how it functions, and the maintenance (mainly clean-up) involved.
I recommend highly to seek out books on airbrushing at your local library, scan through articles in AIRBRUSH magazine and similar titles, do a search online, and finally, check out this FAQ: http://www.io.com/~fazia/arbrshfq.html.
Don’t forget to look at the resources on is this website.
Below are listed the different manufacturers as used by Forum members, and either statements or summaries of their experiences.
AZTEK
There is a wide spectrum of opinions concerning this series of airbrushes, ranging from “Oh-Lord-save-me-from-this-airbrush-from-hell!” to “have an Aztek and it works like a champ!” (RonUSMC).
Positive aspects:
-Ease of use (single or double action)
-Easy to change spraying style through screw-on tips
-Easy to clean (only need to clean the tip)
-Lightweight
Negative:
-Requires exact air pressure and thinned paint
-Inconsistent
-Sputters, leakage behind needle/nozzle
-Paints do not perform well
-Feels cheap
Model 430
Negative:
Spraying and sputtering, leakage behind the nozzle. Metallic/Pearl paints tend to run around spray edges.
Model 470
Notes:
-Make sure the tip is set right, and tightened properly
Positive:
Ease of use, easy cleanup.
-“have used it successfully for about 6 years now for a multitude of applications” (renarts)
-Success with acrylic paints, enamels, laquer paints, clear coats, and Future
BADGER/Thayer&Chandler
General:
-Smooth, right out of the box. Excellent results with a standard hobby compressor.
-Easy to maintain
-Watch for the weekly Michael’s ad, and the 50% one item (regular price) coupon. I purchased a 350 for $35.
Positive:
-Widely used, easy to buy parts. Virtually every hobby/craft store sells Badger airbrushes and supplies
150
200
Positive:
-“…had it for 15 years and no complaints yet” (sven3839)
-I own a 200-1-IL, and find it a joy to work with
IWATA
HP-C
Negative:
-Expensive parts
Revolution
Positive:
-Atomizes well
-Consistent spray
-Very easy clean-up
PAASCHE
H
Positive:
-“Works good” (Texgunner)
-“… all the airbrush I need” (shermanfreak)
-“Paasche H for over 20 years now. Have 2 of them, one for acrylics and the other for enamels.” (uscsn)
Compressor vs. “Canned air”
For an airbrush to function, a source of steady air is required. There are many ways to supply air, ranging from old car tires to high-end professional air compressors. For the average modeller, who is usually limited in space in their ‘work area’ or ‘workshop’, space and noise levels are not desired. Therefore, two options are readily available: an air compressor or canister propellant.
First, let’s talk about canister propellant. Canister propellant, found at just about any store ranging from Wal-Mart to Art Supply shops, is fairly inexpensive and quiet. The canister, resembling a large spray-paint can, is connected via hose to the airbrush. Simply using the airbrush draws air from the canister.
Postive:
Inexpensive (about $5-10 per can)
Quiet
Does not require a regulator or moisture trap
Negative:
Long-term cost exceeds the cost of an air compressor
your bias is showing. I have an aztek, paschee VL, badger 100LG and Sotar. The only negative experience we share on the Aztek is the fact that they do feel cheap. However I find it very forgiving of paint consistency and I use a wide range of pressure from 10 to 25 PSI with virtually no trouble. The tips rarely leak and sputters much less than the VL does. I also find that the trigger depth allows me to be more precise in terms of air pressure than any badger brush i’ve used.
OK, hold the typing folks. This is a FAQ-only thread…meaning the only post here is the FAQ itself. I’m asking so this doesn’t become a 400-page “what about this?” thread.
Add http://www.dixieart.com/ as an excellent place to pick up airbrushes of all makes at very good prices.
On Badger airbrushes, the 360 is an excellent brush giving full range from fine line to large coverage with one tip/needle and allows for color changes in about 30 seconds and total breakdown in under three minutes. I have used a 150 for twelve years then purchased a 360 two years ago - the 150 gathers dust now. I have compared it to Iwata and Paasche airbrushes and while they appear similar the Badger still breaks down and cleans easier.
On paints, what? No tips for Lacquers? Order of painting should be; any lacquers then enamels then acrylics. Lacquers contain dangerous fumes so adaquate ventilation is required and a good respirator (not mask - there’s a difference) should be worn. Both lacquers and enamels can be thinned with lacquer thinner for airbrushing. Also if you use Testors flat black ever notice how this particular color seems to want to harden in the jar quickly? Add some lacquer thinner to it and it will extend the shelf life considerably.
As a newbie to modeling (actually I’m returning to it after a 40 year break) I’ve tried both hand brushed and spray can paints, and definitely see the advantages of spraying, hence my desire to switch to an airbrush. However, I’m at a loss as to which airbrush to buy. I could really use some guidance as to which airbrush(es) would be best to start with. I’ve tried doing web searches for comparative reviews by users of the various makes and models, but I have only been able to find reviews of a particular airbrush, or listings by manufacturers of the airbrushes they make and the features each model has. Better yet, I’d love to see some more responses from the more experienced modelers as to the makes and models of airbrush(es) they use, why they do and don’t like a particular make or model, what they would recommend for someone who is just starting out, and why. There is some of this here, but it seems rather limited. Is there a forum on this site that goes into this issue in more detail, or a link someone knows of where I can find more help on how to select a particular make or model?
Also, on the issue of compressors and canned air, what about the use of an airtank with a regulator? I have an electric compressor I use to put air in the tires of my car. Why not connect that to an airtank, fill the tank, and then attach the tank to the airbrush? It would seem that you would have a much larger and more continuous source of air than a can, but without the continuous source of noise from a compressor as you only need to run the compressor long enough to fill the tank.
Hello,
I am having fits spraying Gloss white. Any tricks that I should know about? I have tried Enamal and Acrylic and can’t seem to get it right. Thanks in advance.
This is so true…I find it easier to use a light primer under my light colors…if you are painting over a dark color forget it…and remember when airbrushing…thin layers…it may take a long time but it is well worth it!
I have just started using an airbrush (paasche - single action). I am going to use enamel paints. What is the best way to clean my airbrush afterwards. I was told enamel paints make it harder to clean the airbrush. What solution do you suggest for the best clean up.
