I asked this question in the armor forum maybe this is a better place for it. I’ve added my base coat of panzer grey (acylic in this case) and now I am about to lay the top coat in this instance desert tan ( enamel) now I’m assuming that if I thin this quite abit and apply it I will get the effect of the base coat showing through and after a little dry brushing I should get the effect of a weathered faded look, correct? keep in mind that I’m using a single action external mix sprayer, not much better than a rattle can. And finally this is my first experience with enamels, model masters, is there anything i should do differently when dry brushing? Thanks all very much, just getting back into the hobby and each new build is a learning experience. And yes an air brush and compressor is in my very near future, probably next build if I can squeeze in my budget.
Thanks! And Happy Easter! Doug in Indiana
