F-4B
Am building a Has 1/48 F-4B. There is a small bump on the top(in the middle) of the wing, should it be there. I have seen models both with and without.
Thanks. Gumshoe59.
That bump is a post-production mod used to cover an upper landing gear mod. Early Phantoms did not have it, some later ones did.
Darwin, O.F. [alien]
Yardbird is right. I’m thinlking that since you are building a B model, as opposed to the later N models(rebuilt Bs), there should not be a bump over the MLG. The wing should be flat.
Chris Ishmael.
Thanks for the info
Gumshoe59
Thanks for the info
Gumshoe59
