I may have asked this question before if so sorry I"m getting old and I’m having to write things down any more to remember
My question for the day I ’m trying to work on one of my many projects and I’m having problems with finding the right color schemes for F-4 phantoms in SEA colors I found 3 sites and all the colors don’t match but one. I have over 100 bottles of paint in my work area and I’m betting I don’t have all the colors and I just spent 40 bucks at the HL the other night. thanks J
USAF Birds originally went to Vietnam in 1965 in the same scheme as their Navy/Marine Corps cousins, Gull Gray over White. Soon they were starting to receive a camo scheme of Dark Green 34079, Medium Green 34103, and Tan 30219 0ver Lght Gray 36622. That was the standard scehem from late '65 until the withdrawl of US forces. A few F-4s had the light gray bottom painted black for night operations.
Thanks I might have found the problem I use MM paints and I have all the colors listed the problem is some sites are calling the 34079 field green not dark green Field green is listed as 34097 medium green 34102, dark tan 30219,and the gray is called camo gray 36622
Rely on the FS numbers and not the paint names. It sounds like they were mis identified. Field Green is usually listed as 34097, which is not a clor commonly used by the Air Force in that time period. And yes another name for Gray 36622 is Camouflage Gray.
This site has an excellent database on aircraft color schemes. Click on the appropriate letter such as “F” for the F-4 Phantom and then click on F-4 Phatom when it appears in the drop down menu. In the “colors and markings” section on that menu, the various paint schemes with their FS numbers and patterns are listed.
Actually it would be more brown than tan so either Tamiya Nato brown or even Model Master Earth brown would work.
I am working on a Hasegawa 1/72 F-4E right now that is going to be in SEA camoflage and right now I started on the Stabilators and have all the colors on but only have 2 of the colors pictured since I shot the brown color on a couple minutes ago and will get a pic of that when it dries.
Stabilator with NMF added
BTW there was a goof on the upper portion that I fixed prior to adding the faded olive drab which is my medium green portion of the camoflage.
Stabilator with Model Master Faded olive drab color.
Stabilator with Tamiya Nato Green added as the second shade.
I am trying to get as close to the camoflage pattern as I can on the stabilators as these will be added last so I can add them to the plane when I finish assembling and painting the rest of the kit to avoid ruining things.
all four are listed on this page, and they are the same 4 used for any USAF aircraft painted after the initial deployments of various gray aircraft (the gray aircraft could be considered confusing, some were Naval gray instead of USAF colors)
I used Nato Green and Faded Olive Drab as that is what I have available and they actually do match up to the pictures color wise I just need to grab the right brown as the Nato brown actually looks more like Vietnam earth than anything else.
