F-16C Block 30 Weapons Load Out?
I’m building an F-16C Block 30 and I want to load it out as either a Wild Weasel bird or a Ground Pounder. Also to be taken into consideration is the fact that I am modeling a F-16 that flew out of Ramestien in 1991. Any sugestions on the load outs for these two configurations would be appreciated. Thanks
Have you tried going to the Air Force website. They have quite an extensive picture library. Also try the historical section.
Hey Sam;
I’ve worked the F-16 for 8 years from blocks 2 to 30 and they are loaded out generally with AIM-9’s or 120’s on the stations 1 & 9 Also on 2 & 8, then on stations 3 & 7 they generally have a TER(Triple Ejector Rack) loaded with MK 82’s or GBU-12’s or just loaded with AGM 64’s, stations 4 & 6 generally have the 370 gal fuel tank but they also have carried the MK 84’s or GBU 10’s or GBU 15’s on them too, then station 5 has the center line 300 gal fuel tank or ECM(Eletronic Counter Measurement) pod 131or 119 now the blocks 40 to 62 have provisions for the FLIR LANTERN pods and now the LITENING II pods which gives the pilot all weather day or night targeting capabilities even the A-10’s are now carring the LITENING II pods too you may want to check out the F-16 Walk Around book that is released by Squadron Books they should have a really good photo library
