I am currently building Tamiya’s 14A Tomcat. I have a set of decals from Eduard.
The specific aircraft that I’m trying to build is VF – 111 sundowners USS Carl Vinson, Miss Molly.
My first question is underneath the nose and what is it and is there an aftermarket for this kit?
The second question is under the fuselage with the tiger shark keys and is there an aftermarket part for the kit?
I haven’t seen the Edward decals for this aircraft, but hopefully they included the nose art for both sides. Most decals for this plane initially only included the nose art for the left side, but it was painted on both.
I’ve got a 1/72 Hasegawa version in the stash that only has it on the left. I’ll probably still build it as Molly, no one else who will see it will know.
It’s funny, I have the Tamiya A and never did an in depth look.
You’d think such fuel tanks would be provided as their F-16 line comes with fuel tanks.
I also have a couple of Hasegawa’s F-14As and I’m wondering how far off of a fit they are so they could be used on the Tamiya kit?
I am sure some tweaking of sorts will need to be done.
Hey Marc,
Ok, so I pulled my Tamiya A from the shelf and it in deed come with the drop tanks that are in question.
Parts E15/E16(tanks) and D19/20(pylons). My kit is No. Item 61114
I’m going to take a shot in the dark that your kit did not have the said drop tanks?
Hey Marc
After digging around a bit, the anti glare panel color and the canopy frame looks to be black outlined with red pinstriping.
I’m surprised that the decal instructions don’t give a color callout as this is an important part of the aircrafts paint scheme?
Here’s another angle and this too appears to be black.
VF-211 transitioned to the F-14A in 1975. The squadron used a partial black hood around the front windscreen (anti glare panel). So basically from the front edge of the canopy rails all the way to the back is Insignia Blue FS 35044. From the back edge of the front windscreen to the panel line of the radome, it’s flat black. Then from the radome forward to the tip is Insignia Blue.
The pic below is my friend’s build for reference, hope this helps.
Steve
According to the Monogram guide, the standard at least through '93 was that all airframe surfaces that could produce glare (or induce strain from brightness) in the pilot’s or copilot’s eyes were to be painted in nonspecular black, unless the aircraft was painted in a tactical paint scheme, in which case they were to use NS Gray (36320) or Blue (35237), both of which look very grey to me! I would assume that anything that looked dark bluish was likely due to UV / color aging, as I doubt they would have used a dark blue where NS black was specified.
Edit: Any anti-glare that looked dark bluish. Not trying to say that other blue paint was NS black!
The first pic IMO is a flight sim screen grab, it’s also depicting a B model. The second pic is from the 1978 time frame because the last two digits of the modex are moved from the fin caps to the inside of the tails and they are larger.
Steve
U.S.A.F. had TISEO on the lefy wing on some “E” and “F” model F-4’s I had seen it on the German owned “F’s” used for traing german pilots at Luke A.F.B. in 1979-1980.
The second photo is the plane he’s depicting minus the carriers name as this was prior to rotation.
The first link is in reference to line drawings and even though the first aircraft has a different plabe number, still the same scheme from 75.
Happy Modeling,
