F-100C Super Sabre-1/72 Trumpeter
This is the last kit I will start. I have too many started and need to take a break. From now on I will only post when something major gets done. I am getting nowhere fast. I have this started , the intake trunking is built, I painted the interior aluminum and the nose wheel well green. I also figured out how to close the brake unit on the bottom of the fuselage.I put the brake parts 8 and 12 together but first I cut the little nubs off item 12. I then placed them in the right fuselage half not glued together, when they fit good in the right fuselage I then glued both pieces with Tamiya thin cement. once that was dry I slipped the left fuselage over them, it fit well so I taped it to check the fit, not perfect but not bad either. I am going to take a break and decide which direction I am headed, wayyyyyy too many kits started.NOTE-fuselage halves are taped together for a test fit only.
I will definitely keep working on this one. It is coming much better than I expected. I have the cockpit done and on the intake trunking then The fuselage halves taped up. It has an excellent fit with the trunking to nose intake. There is still a bit of a gap behind the air brake but if I squeeze the halves with my fingers it closes up good. The wheel well and cockpit fit snug.
I added 17 grams of weight in the nose, installed all the interior parts then closed up the fuselage halves. I used minimal putty on the bottom seam.
The canopy is on, fuselage gear bay door closed up and the bottom fuselage is puttied and sanded.
The wings are assembled, slats open.
Wings on.
