Alright! My Kiowas are coming along, but they’re at the point where I had to put them aside for a while. While they sat, I got started on my Hueys.
After opening the packaging, I noticed that the cream colored kit had some loose bits floating around in the plastic. Unfortunately, one of the broken pieces was the landing skid. I figured before I went too far with the fuselage build, I’d better make sure it’d have something to sit on. So, my first order of business was to fix the broken gear.
I was able to drill some holes and, using some wire, (luckily) pinned everything back together.
What I noticed about this plastic is that it is very brittle. I don’t know if that’s the type of plasitc that was used, or if it’s a function of the kit’s age. Regardless, parts on this kit break easily. As I was prepping the cockpit and cabin assemblies, I saw that one of the control sticks was broken.
I used some wire to make a new one.
It’s not perfect, but I was confident it would look OK under paint and in the closed up fuselage.
Speaking of the cabin area, during dryfitting, I noticed some large gaps under the cabin floor that would be fairly visible through the chin windows.
I fixed that with some thin styrene sheet and a sanding stick. (Much better, eh?)
I plan on building these as some early -Ds which had grey instrument consoles with black instruments. However, the consoles were free of molded detail, and the instruments were to be represented with some decals. The decals are printed on a black, not grey, background. I was OK with it because little would be seen once the cabin was closed up. However, the decals for the cream airframe were completely unusable. So, I dug through my decal spares and found some “instruments” from my A-7A.
I cut them up to fit the Huey parts and called it a day. I was just going for something of a representation of instruments. I think the decals pull it off.
Anyway, I went ahead and got the cabin areas completed. I added inertia reels and the U-shaped harness guides to the pilots’ seats, as well as some paper seat belts. Again, not accurate, but representative. After painting things up, I used Flory washes and some oils to dirty things up a bit.
Here’s where things are at…
Next I’ll be working on the engines and the transparencies before closing up the fuselages. After the hassle I had with the Kiowa windows, I am not looking forward to dealing with these Hueys’ windows. There are 13 clear parts per kit! (Ugh!)
Anyway, the Hueys are now “in progress.” As usual, comments, questions and criticisms are welcome.
Thanks for lookin’!
-O
