Engine Trouble!
I just started building the Classic Airframes Curtiss BF2C-1. I completed the cockpit and moved on to the engine, only to realize that the gear case that the cylinders attach to is missing! Does anybody know if CA has a part replacement service? I am looking at a B-17F engine out of the parts box that I might be able to make work but I would prefer to have the correct resin part.
Mate,
The first comtact point should be Classic Airframes themselves…try to contact them on contact@classicairframes.com
Maybe they’ll be able to help.
Good luck - hope you get what you need.
Thank you for the contact info LeeTree, I sent them a note. In the mean time I found an engine from a scrapped Monogram AT-6 that with a little modification should work fine if I can’t get the original part.
