I know this has been answered to death, but the search function doesn’t seem to find the answers I seek-
So, what I can I use to strip fully cured enamels and lacquers from a kit without melting the plastic? I seem to recall reading about either brake fluid, or brake dust cleaner to do this, as well as oven cleaner.
I can immerse the area that needs stripping, so that’s a plus. Oh, the paint is 2 years cured and has Tamiya tape melted into it (don’t ask) if that matters.
Dre, There is a product called ELO (Easy Lift Off) that is (was) made by Polly S that is specifically designed for removing paint from plastic without any ill effects. I believe it is now put out by Testors. The stuff works wonderfully. In fact I just recently used it to remove a section of paint on my 1/72 FW 190 that had met with an unfortunate decal removal incident. I removed a small area of the camo and repaired it successfully.
Gunze Mr. Color Lacquer thinner will remove both types of paint and is safe on plastic. No need to soak the model in it, just wet a paper towel and wipe it off.
